15x7 or 15x8 for my SE but must be <5kg each!
Randy
Postby Randy » Wed Nov 07, 2007 4:56 pm
Would going down from 17 to 15 inch hinder the brake cooling??? Only reason that i ask is that i had tried 15's on mine and didn't like the fact that the discs were so close to the wheel rim. I thought not enough air would flow around the discs.....or was i just being paranoid??? :frown:
Form is temporary.Class is permanent.
PUR157
Postby PUR157 » Wed Nov 07, 2007 6:34 pm
Methinks paranoia
If you ask me... I'd say rim geometry and design would be the factors to affect brake cooling...
But if you did the maths... there can be quite abit of swept area to an extra two inches of radius I guess
Design a rim that DRAWS air into the rotors... now that's something to look into
Oneness of Man and Machine
irwin83r
Postby irwin83r » Tue Nov 20, 2007 11:05 pm
PUR157 wrote:Methinks paranoia
no no no...
draws air out.. that way air still passes the rotor but it is being sucked from under the car not jetting up under the car... think old F1 airofoil skirt thingys :D
Dodgy Haro
Postby Dodgy Haro » Wed Nov 21, 2007 1:34 pm
ASE05 wrote:I'm now thinkin' about 15x9 for the rear with a +25 running a 225/50/15 R spec tyre and a 15x8 +25 with a 205/50/15 R tyre. I have no idea if this set up will work or not so I'm throwin' the line out to yall fopr advice!
Yes it will work - I am surprised no one has mentioned Peter Lee's old car from the Club Roadster forums:
http://forums.vwvortex.com/zerothread?c ... id=3378904
Unfortunately Work Equip are not manufacturing any 14" rims until early next year ... best to get your order in as soon as you can afford them.
I fell in love with Peter's car and have placed my order in similar specs since August but they won't be arriving till next year ... :roll:
As for getting Work Equip 03 under 5kg's ... er, dream on but they make your car a baller IMO ...
Btw ... 15x9 with zero offset without flares works too:
http://clubroadster.net/forum/viewtopic ... ht=#158280
ducktape69
Postby ducktape69 » Wed Nov 21, 2007 1:44 pm
holy crap. i just crapped my pants! thats gorgeous!
BLECK 2002 Mazda MX5 NB8B. Custom Heatshielded CAI . KYB AGX's + King Springs. 17\" Bleck Rims. Custom BASSSS Install.
PUR157
Postby PUR157 » Wed Nov 21, 2007 11:48 pm
irwin83r wrote:draws air out.. that way air still passes the rotor but it is being sucked from under the car not jetting up under the car... think old F1 airofoil skirt thingys :D
Good point... hovercraft effect for a car isn't desirable now is it...
buliarios
Postby buliarios » Sun Nov 25, 2007 9:25 pm
ce28n's the way to go, light, strong, and look sexy with a +25 offset. its what i have on my car for track work. they are the second lightest wheels from volk racing. the lightest is the latest RE30.
AB7
Postby AB7 » Mon Nov 26, 2007 12:22 am
buliarios wrote:ce28n's the way to go, light, strong, and look sexy with a +25 offset. its what i have on my car for track work. they are the second lightest wheels from volk racing. the lightest is the latest RE30.
Hei buliarios, do you have any pics to share of CE28 fitted on your car?
Steampunk
Postby Steampunk » Mon Nov 26, 2007 9:47 am
Are wheels and tyres that stick out like this legal?
or have the pictures been on limited road-use registered cars?
irwin83r
Postby irwin83r » Mon Nov 26, 2007 6:11 pm
lol
irwin83r
Postby irwin83r » Mon Nov 26, 2007 6:14 pm
1red5 wrote:Are wheels and tyres that stick out like this legal?
not legal unless you can convince an engineer to certify it...
other wise your only (in NSW) aloud to go 1" wider on total track and 1" wider on total width.. (could be wrong but its something like that) ive also been told the wheel isnt aloud to protrude the wheel arch but i swear some new cars with factory tyres do now days :|
regardin wheel weights these two sites are worth a book mark. 8)
http://www.miata.net/faq/wheel_weights.html
http://www.wheelweights.net/
Users browsing this forum: No registered users and 369 guests
