Oni
Richee wrote:Hi Oni
A number of MX5s do this - this issue has been discussed before and is vibration from the gearbox due to wear, I searched quickly but couldnt find it.
Jules knows all about this - Jules where are you??
Nothing you can do about it, perhaps change the gearbox but it could still be there.
Richard
should see some liquid on the ground if its cracked
that was caused by wear in the gearbox casing where the shift rods sit. It required a rebuild
They couldn't work out the noise, but he found it, and after replacing the gearbox casing the sound went permanently.
