Okibi wrote:Your MX-5 should already have a second radiator, attached to the hottest outlet on the engine and carefully hidden up under the dash.
yes i'm aware of that and it's actually what got me thinking about this... i was thinking that you cold plumb that another small radiator after the heater somewhere. it shouldn't be too hard to plumb in, as you will be using exisint pipes and just adding a little bit of extra stuff between them. BUT, does al the coolant actually go thru the heater?
but then where do you put the thing...
JUFFA -
my intercooler is the AVO one, it's bigger than the one i sold to you, the size is about halfway between what you have now, and your previous one.
i was also thinking of downsizing to a smaller intercooler, and adding water injection that only kicks in at higher boost levels.
that scooper thing looks pretty cool too.
