yep that'll do it!.. after reading your post i looked at my car and figured out what you had done
unfortunalty i didnt keep the ones off my wreck.. ring mania.. you only need the right one.. and it doesnt look dumb as you cant see the hook anyways
GROUP BUY - Number Plate Bracket: Front or Side Mount NA/NB
- Ajay
TP13SS wrote:hey raymo!..
mine cleared the bumper with HEAPS of room.. did you pull it as far forward as you could when you were doing up the bolt on the tow hook?
Ajay
Hmmm ... there weren't any instructions so I just used the bolt + washer ring to secure the license bracket to the tow hook ... is there any secret apart from just tightening it enough so it is secure?
- kenson
I had my car reversed into and the protruding screws wrecked my untouched front bar
This bracket looks like it would solve some problems and looks good too. What number plate sizes fits the bracket? Sorry if this has already been answered!
I scrolled through the thread quickly. It looks likes a lot of you have personalised smaller plates. I just have the normal sized WA plates
Ken
Ken
- Jimmy
- Boags
JimmyJ5 wrote:What number plate sizes fits the bracket?
If your going for personalised plates then order them without holes. It means that u drill them exactly where you want them to be and you dont end up with holes which arent used.
ALL plates should have holes in the same place to comply with ADRs. Richard has MOST CERTAINLY designed these to comply with the ADRs. ALL plates fit.
Boags
- marcusus
I'm a bit late to the party, but you can see a shot of mine here. Yes I know it's wonky. I need to adjust that
Incidentally, is that spot about how high everybody else's sit? I swear it looks like it's lower than everyone elses...
Users browsing this forum: No registered users and 91 guests
