Coolant reroute
zoomzoom
Vehicle: NA6 - Turbo
Coolant reroute
Postby zoomzoom » Thu Nov 15, 2007 10:23 pm
Thought I would put up a couple pics of the coolant reroute I just did.
I had a new front neck made up to put the ecu temp sensor in and for a heater outlet. I had one made up in preference to just using a 1.8 front neck to clear the front on the engine as much as possible. The pipe I just had bent up out of alloy which goes down to the 1.6 thermostat housing which is relocated to the back of the head. Alternatively a datsun 1600 thermostat housing can be used on the back of the head.
Thanks to mx5 plus for the help and bits too.
Cheers, Tim
sabretooth
Postby sabretooth » Fri Nov 16, 2007 9:41 am
I see your air filter has improved :)
That's looking great. I'll have to come check it out in person. How was the cooling yesterday? Any problems?
Fra66L
Postby Fra66L » Fri Nov 16, 2007 11:26 am
Doing this mod myself at the moment. I've got the head off anyway so that makes things a little easier. I'll post again why I've got it up and running, but I'm keen to see what difference it for you...
T
The Green Meanie - Grace Green NB8A
Veilside - It's Japanese for UGRY!
