Stones in muffler?
Stones in muffler?
Postby sliq » Wed Nov 14, 2007 6:20 am
Hi guys,
I recently bought an SMB catback off black max which is yet to be installed. After lifting up the muffler (not a straight through muffler), there appears to be some clinking going on inside of there which I suspect are stones or little rocks or pebbles. Is there a way to remove these? Or is there no point? Will I be able to hear these little stones clinking around whilst driving/make a rattling sound? And more importantly, will it affect the performance of my 5/damage the muffler in the long run?
Any help would be muchly appreciated. 8)
sliq.
JBT
Postby JBT » Wed Nov 14, 2007 7:02 am
If that is the cat converter you're talking about, it indicates that it has started to fall to bits internally. Loose ceramic bits or something.
Postby sliq » Wed Nov 14, 2007 7:25 am
this was what i was talking about jbt. thanks.
JBT
Postby JBT » Wed Nov 14, 2007 8:11 am
Loose baffle or a bit of cat converter got into it then would be my guess.
Steampunk
Postby Steampunk » Wed Nov 14, 2007 8:35 am
Perhas some welds may have gotten dislodged in the casing, cause if there is something in the actual exhaust path, then jiggling it around, flipping it over and over, etc. would eventually get it out.
Take it back.
AB7
Postby AB7 » Wed Nov 14, 2007 10:21 am
Hei Mike,
If its like tricking sound, nothing too heavy or loud then its ok. Its happens a lot with any seconhand muffler. Its mainly due to the carbon buildup and some of it had cristalized and fallen into chunks.
Like I said, it should sounds like light trickling...nothing heavy like pebbles inside it.
Steampunk
Postby Steampunk » Wed Nov 14, 2007 10:26 am
Uhmmm ... Sliq ... you do mean that the rattling is in the muffler that you JUST bought new? .... :roll:
mr_rotary
Postby mr_rotary » Wed Nov 14, 2007 11:27 am
It's parts of the cat still inside your exhaust. Mine had failed and I got it replaced however the exhaust shop left some of it still in the exhuast pipework.
Postby sliq » Wed Nov 14, 2007 3:48 pm
1red5 wrote:Uhmmm ... Sliq ... you do mean that the rattling is in the muffler that you JUST bought new? .... :roll:
nah mate, it's second hand..
AB7: yeah, my old man said the same thing.. i've tried jiggling it around, it still won't come out.. you're right, sounds like a light trickling sound. nothing big :P
Postby bruce » Wed Nov 14, 2007 4:09 pm
Fit it, give a big rev and see if it blows out.
JSE
Postby JSE » Fri Nov 16, 2007 4:09 pm
yeh what brucey said...put it on and go for a hard fap
