hi,questions of 17' rim on NA6 thanks
hey, everyone, i have some questions about upgrade my current wheels.
I have 185/60/14R on my 1990 NA6.
i am interesting of buying a 17 inch wheels, detail sa below:
Kspeed Daytona 17\"x7\" with Nankang 205/40R17
4x100 & 4x114.3
offset 40
Anyone put 17 inch rims on NA6? have any problems like wheels are too big, can contact with your suspension or something?
anyone using 17' on their na6 to TRACK DRIVE? any good?
cheers
4x100 & 4x114.3
offset 40
cheers
- Boags
Re: hi,questions of 17' rim on NA6 thanks
lanoshow wrote:anyone using 17' on their na6 to TRACK DRIVE? any good?
For the track? No good at all.
Boags
- adamjp
When I bought my car it had 17x7 Speedy wheels on it.
I think that the most polite way I can express my regard for this size on an early MX5 is to tell you that I am now running 15x6.5.
The problems with the 17's....
Tyres are very expensive, and hard to get. Good tyres even more so.
They weigh far too much - this affects the ride, and the acceleration of the car.
The thin sidewall can setup some difficult handling issues.
It does not take much to get a flat.
The rims rub against gutters so easily it is not funny.
You lose any ability to deal with rough roads.
The advantages of going to 15's....
Good tyres are cheap (~$100 each per rim less than 17's).
The selection of tyres is excellent.
Good rims are available cheaply in 15.
The police cannot hassle you over wheel size.
Rough roads OK.
Acceleration better.
Handling better.
Ride better.
Gutter rash gone.
Normal sized tyre = no problems with a repair.
In short - don't do it.
Rough roads OK.
Handling better.
Ride better.
Gutter rash gone.
Adam
agree with everything above.
Also your rolling diameter will be increased by i think approx 1.8 - 2 cms total if your going from 185/60/14 to 205/40/17 ... trust me im hanging to get rid of my 17's!!! when i find the right set of 15's my 17's will be going in the bin! (maybe literally haha)
my 2c
mark
my 2c
mark
adamjp wrote:When I bought my car it had 17x7 Speedy wheels on it.
Rough roads OK.
Handling better.
Ride better.
Gutter rash gone.
- Steampunk
- adamjp
Acceleration does not just drop due to the increased diameter.
It also drops because the wheels weigh more AND that weight is further out on the circumference of the wheel. Both of these bad things increases the rotational inertia of the wheel, which reduces your ability to change the rotational speed (accelerate or decelerate).
In simple terms, it takes more energy to accelerate a heavy object if it is further out from the central point. Think of a fishing sinker on a piece of string, simple to twirl fast on a 5cm string, harder on a 10cm string, harder still if you double it's weight.
Adam
- AB7
I read somewhere that 1 KG inclease in unsprung weight equal to around 10 KG in actual rotational inertia of the wheel? Is that correct?
BTW just say that the 17" + tyres size and weight combo is the same as 15", would it be the same?
adamjp wrote:Acceleration does not just drop due to the increased diameter.
As everyone else has said, from a performance angle, don't do it!
But even if you decide to get them anyway because you don't care about the performance or the feel and just want to look cool when you pulll up outside the cafe, I'd still say don't get them. +40 offset on a 7 inch rim won't look at all tough, they'll still be an inch and a half/two inches inboard of the edge of the guards. If you get big wheels just to make the car look cool, do it properly
- meanmx
Do a search. This topic has been done to death. If you like it do it!!! Plenty of NA drivers have 17's and love them, myself included. You may want to definately lower it afterwards as it will sit quite high.
Ben
Ben
2014 VW Mk7 Golf R
- adamjp
Mate I can't remember the formula, just the principle
But if I remember it correctly a 1kg increase (on say a 8kg rim) at the outside circumference, is far more than a 1/8th increase in rotational mass. Probably a radius related function.
A quick google sends me to the moment of inertia page on Wikipedia...
http://en.wikipedia.org/wiki/Moment_of_inertia
BTW just say that the 17\" + tyres size and weight combo is the same as 15\", would it be the same?
No, not for the vehicle acceleration part. The weight is distributed differently. It is always going to be worse unless the rim is so much lighter it is not funny.
For other handling related issues (acceleration of suspension) it should be no different as the weight is now acting in a different plane.
Adam
yup this topic has been done to death on every mx5/miata forum.. but hell do we all like responding to it when it crops up again haha.
at the end of the day mate do whatever you think is best for YOUR car and YOUR style .. thats all that matters
meanmx wrote:Do a search. This topic has been done to death. If you like it do it!!! Plenty of NA drivers have 17's and love them, myself included. You may want to definately lower it afterwards as it will sit quite high.
Ben
Users browsing this forum: No registered users and 102 guests
