Suspension Install Guide
Kvision
Postby Kvision » Mon Oct 29, 2007 7:20 pm
This is probably the best guide I've come across to install suspension for total n00bs. Large and clear close up photos for every step! With this guide, I managed to install my Tein SS by myself and am one happy chappy! :D
http://www.villacorte.com/miata/gc_coilover/index.html
fundies
Postby fundies » Mon Oct 29, 2007 10:08 pm
Very good. Is this procedure the same as a shock/spring change on an NB?
Stu
Postby Stu » Thu Nov 08, 2007 12:13 pm
Good Find
atomic
Postby atomic » Thu Nov 08, 2007 9:37 pm
On this site which is linked from the page you gave, it says:
\"A Miata even with its stock suspension corners on the bumpstops essentially all the time.\"
Just wondering how true this statement is.... ?
Postby Okibi » Thu Nov 08, 2007 11:55 pm
I seem to remember, Keith Tanners book has a great write up about changing the shocks.
metris
Vehicle: NA6 - Turbo
Postby metris » Mon Dec 17, 2007 12:16 pm
...revival!
i was told that i would need a coil spring compressor to get the old springs off and new springs onto my NB?
is that right?
in this guide it doesnt seem like you need it at all???
NA6 turbo cute scary fun machine!! :D
Kvision
Postby Kvision » Mon Dec 17, 2007 1:56 pm
I think u'll be needing a compressor for installing/removing springs.
metris
Postby metris » Mon Dec 17, 2007 2:29 pm
have you seen the guide tho? he doesnt use any... or it doesnt show him using any...
StanTheMan
Postby StanTheMan » Mon Dec 17, 2007 2:30 pm
ROFLMHO.......
you don't need that. It makes it very convenient though
metris
Postby metris » Mon Dec 17, 2007 2:32 pm
dont laugh at meee!!!!! :mrgreen:
okay so if i DONT use it, what the chance of getting smacked in the face by a spring..?
AJ
Postby AJ » Mon Dec 17, 2007 2:33 pm
fair to very high...........of course, you could be lucky & lose the fingers off one hand BEFORE it smashes your jaw to pieces :lol:
XMX5 Rogues
metris
Postby metris » Mon Dec 17, 2007 2:35 pm
ooookay im convinced. I'll buy a compressor...
thanks guys! :D
NMX516
Postby NMX516 » Mon Dec 17, 2007 7:15 pm
If you're changing springs and not shocks, then yes you'll need a spring compressor - don't attempt changing springs without one. If you're changing the whole coilover setup, as per Teins then the springs are already fitted to the shock, so the coil over assembly just bolts straight in.
I used the \"long bolt method\" for the front, and consider that to be the easiest way of changing the fronts...
timk
Postby timk » Mon Dec 17, 2007 7:49 pm
NMX516 wrote:I used the "long bolt method" for the front, and consider that to be the easiest way of changing the fronts...
Ditto!
Juffa
Postby Juffa » Mon Dec 17, 2007 8:46 pm
Bah humbug.......
You DO NOT need a spring compressor to remove/fit spings and/or shocks in an MX-5. I have replaced the springs while leaving the shocks in place.
As copied from a number of similar posts I have made on the big forum.
There is another method to remove springs without a spring compressor. I have used this method a number of times without injury to the car or myself.
Use your preferred method to ready the spring/shock absorber for removal, ie separate the ball joint or remove the upper A arm bolt.
Using a scissor jack to press up against the bottom of the suspension, ie on a point where you can safely apply upward pressure without the jack slipping.
Raise the jack until the spring is compressed. Be careful not to raise the jack to the point where the car is lifting off the jack stands.
Loosen and remove the single upper shock absorber nut. (do not do this unless the spring is being safely compressed by the scissor jack).
SLOWLY lower the scissor jack thus releasing the pressure on the spring. The spring will un-compress as the pressure from the jack is removed.
Once fully released the spring should be loose and ready for removal.
Pressing down on the lower suspension arm will allow the spring/shock absorber to be swung free from the upper mounting point.
At this point the spring and shock absorber can be removed.
Installation is a reversal of the above.
J
Users browsing this forum: No registered users and 349 guests
