Another Audio Install-Look Mum I still have BOOT!!
Thanks to FHRX for some very tidy work and for making sure my 5 is still a practical daily driver.
11\" sub
3 Channel Amp
The Final install
Oh almost forgot the Stubby aerial
Thanks to JBT for the excellent sticky on posting pics...My first ones on the forum.
11\" sub
3 Channel Amp
The Final install
NB SE
- Alex
Nice work, I checked out the NB install on their site and that was what started me thinking about fibreglassing when I did mine
I didn't think an 11\" would fit, my 10\" wouldn't fit oriented like that and either would my amps *sigh*
How much extra weight does the boot lid have on it with the sound deadening?
maybe I'll start a new install in a few weeks, it'll be number 4 for me
Looks great, do you mind me asking the price? or at least give a rough idea for anyone thinking of having this done
- jules
- Guitar Hero
- Boags
- Benny
SM wrote:Nice work, I checked out the NB install on their site and that was what started me thinking about fibreglassing when I did mine
I didn't think an 11" would fit, my 10" wouldn't fit oriented like that and either would my amps *sigh*
Thanks for the kind comments guys.
The actual cost was more than I wanted to spend as is always the case however it was less than the work involved equates to.The biggest cost was the amp and sub.SM the box cost depends on how the prospective owner wants it done anywhere from 250 for a basic enclosure to about a grand...they can do it in carbon fibre if someone wants it,the cost of the enclosure was not too bad considering it would have have cost heaps more in time and false starts if I had attempted it! The bootlid is pretty heavy without the Dynamat so not a lot of difference there and is well worth doing.I have a gas strut bootlift kit from Mania that works fine. Good luck with the next install.
Hi Benny, it's no SPL bass monster but fills out the bottom end nicely but being a convertible the 5 needs good in-cabin speakers that are punchy.SQ wise not bad but the stock tweeter location isn't ideal.Of course I couldn't afford Focal Utopias which i gather are a favorite of yours. Now 4 those babies custom A pillars would be worth doing.
All I can say is that I never bothered with a sub before as I was told by another shop that they could only do an 8" in that space. I am happy to confirm a 11" fits very well.
NB SE
- marcusus
[quote="marcusus"]I wonder what the possibility for a 12" is if it's mounted on a slight angle.
I was told a 12 would fit (on the non battery side) but bear in mind it it needs to be relatively shallow mount (one of the reasons I went with focal, a DLS nobelium would work too) as well as be able to work in a small enclosure , the space behind the sub is just over a cubic foot if I recall correctly and involved using the cavity left by removing the plastic tool container.
"How does the sound (I guess its only bass) find it's way to the cabin? Through the back wall of the cabin? Dumb question..."
As to bass in the cabin,that is a perennial problem with convertibles and in this case is compensated for by running good splits upfront to play some of the audible bass (sound deadening in the doors works wonders here but of course weight may be an issue).Also I have a reasonably grunty amp with gains set higher than u would in a hatch.There is probably a (complex) way of building a port through the gap behind the trim and over the rear shock tower but I havn't explored this as the current set up provides enough bass.Interesting thought though, mmm I may ask the gurus at FHRX about this one
NB SE
- marcusus
BlackMX wrote:I was told a 12 would fit (on the non battery side) but bear in mind it it needs to be relatively shallow mount (one of the reasons I went with focal, a DLS nobelium would work too) as well as be able to work in a small enclosure , the space behind the sub is just over a cubic foot if I recall correctly and involved using the cavity left by removing the plastic tool container.
I hadn't put that much thought into air volumes etc. I just want bass to match treble, rather than have a competition sounding car. It should work I suppose. I don't particularly want to lose that little cubby hole though, as I have a first aid kit and jumper leads in there that poke out a little bit above where the cubby hole ends, which means I wouldn't be able to utilise the space entirely.
Of course I could just leave them floating round the boot, but I'd rather not have stuff shifting around in there if I can help it.
marcusus wrote:I hadn't put that much thought into air volumes etc. I just want bass to match treble, rather than have a competition sounding car.
Know how you feel, I was reluctant to give up the cubby as well and now the toolkit lives in the spare wheel well---luckily it just squeezes in. I went in there with a similar notion "basic box to have some bass, use old amps i had lying around... " Got bitten by the bug and this was the result
Heres pics of the sub cavity,even without the pocket there is a fair amount of space but the stock aerial motor had to go.
NB SE
Thanks quikshift
Bought it here http://www.locustom.com/home.htm
Similar ones crop up on fleabay from time to time for less but i couldn't wait
NB SE
no probs!
the shark attack 2 yeah? the base fits nice n flush?
BlackMX wrote:Thanks quikshift
Users browsing this forum: No registered users and 111 guests
