Tein Super Street settings?
Kvision
Postby Kvision » Tue Oct 30, 2007 12:04 pm
Just got my Tein SS in my NA6 the other day and am looking forward to play around with the settings.
To get on the right track, I was wondering what the general consensus is for damper settings for twisty back roads, for track days, as well as ride height?
Thanks.
Babalouie
godfather of saké
Postby Babalouie » Tue Oct 30, 2007 12:24 pm
For ride height I found that 325mm all round seems to get a good ride. You can get as low as 305mm, but under 320mm it seems to get quite choppy.
My track settings are 2/5, my twisty road settings are 8/8 and my street settings are 12/14.
Postby manga_blue » Tue Oct 30, 2007 12:55 pm
Tein HAs on my car. They have 16 settings from 1 (rock hard) to 16 (stock). I've settled on 4/16 front and 2/16 rear for dry track and 15/16 all round for street. Wet track is prolly somewhere in between.
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Wed Oct 31, 2007 1:50 pm
on this. when you turn it all the way back anti clock wize is that on the softest or hardest setting?
Postby manga_blue » Wed Oct 31, 2007 5:16 pm
On mine there's a warning that you could damage the unit by turning beyond 16 clicks anti-clockwise. You turn it in all the way clockwise until it stops. This is position 1 - the hardest setting.
16bit
Postby 16bit » Wed Oct 31, 2007 6:17 pm
hmm i may have to read the guide again. when i turn mine anti clockwize it stops. but i could probably keep on going clockwise which is where i think it gets damaged
Fatty
Postby Fatty » Wed Oct 31, 2007 6:37 pm
on my SS you turn clockwise to get full hard, then click back from there to soften it up.
Slugoid
Postby Slugoid » Thu Nov 01, 2007 1:21 am
16bit wrote:hmm i may have to read the guide again. when i turn mine anti clockwize it stops. but i could probably keep on going clockwise which is where i think it gets damaged
I think you only damage it when you go past the last position. If you turn softly with your fingers, you can feel where the last position both fully clockwise and anti-clockwise. From what I can remember, from first to last position is around 30 clicks, and that's only gently turning it.
My suggestion is to turn it fully clockwise, which is the setting from the manufacturer, and work your way back. With Aus spec Tein SS, it suggest 12 clicks from hardest as the standard value, while the US Tein SS suggest 8 clicks.
16bit
Postby 16bit » Thu Nov 01, 2007 8:47 am
will do - thanks guys!
Brad
Postby Brad » Thu Nov 01, 2007 9:00 am
I settled on 7/16 and 9/16 for the street now I've got the RB ARB on the front to improve turn in.
As for 'over softening' it, unless you are being brutal with the adjuster there is no way damage can be done.
Users browsing this forum: No registered users and 169 guests
