hard top rattles
garettb16
hard top rattles
Postby garettb16 » Sat Oct 27, 2007 7:13 pm
hey fellas.. when i bought my car it came with a hard top and i am very happy for that. however i went in an exact same MX5 NA6 like mine with a hard top and he had very stiff suspension and his roof didnt rattle at all like mine.. valid it does come off the car so i expect some creaks moans and rattles.
although i have noticed from time to time people advertising hard top latches.. and it shows the hooks which mount at the top of the windscreen. just wondered if they were slightly different or something. and made the roof lock on better..
basically how do i make it quiet? as i am about to upgrade my suspension and it rattles now.. so im expecting it to rattle a whole lot more when i change the suspension over.
Gazbo
Postby Gazbo » Sat Oct 27, 2007 7:58 pm
Make sure that all four hard-top latches are adjusted nice and tight.
Take the lids off the two chrome boxes at the rear of the hardtop and adjust the plates (if neccessary) that lock over the frankenstein bolts.
I traced a rattle in my hard-top to a loose nut & washer on the glass window.
garettb16
Postby garettb16 » Sat Oct 27, 2007 8:27 pm
its mostly the top ones above your head.. is where the noise is coming from
Alex
Postby Alex » Sun Oct 28, 2007 1:52 am
it's quite easy to adjust these latches, open them and you can see a thread with an hex bold on it, just turn that and it will either get tighter or looser, close the latch and see what happens then repeat until it's all snug
ZenArcher
Postby ZenArcher » Sun Oct 28, 2007 9:06 am
I've also found that sometimes it it the hook that is bolted onto the windscreen surround that sometimes comes loose as well. If that's the case you will need a star head screw driver to tighten them up. Well, at least that is what my MX has. Not sure about others.
garettb16
Postby garettb16 » Sun Oct 28, 2007 9:26 am
thanks for the replys fellas... yep the window has the star bolts..
so the hex adjust is the centre spine? i shall have a squiz this afternoon
garettb16
Postby garettb16 » Sun Oct 28, 2007 3:06 pm
i cant beleve how easy it was to adjust .. i didnt even have a close look before today.. has definately made an improvement.
thanks guys :D
Steampunk
Postby Steampunk » Mon Oct 29, 2007 9:38 am
Also, if you take the hardtop off, check the rubber grommets on the underside of the rear latches (the chrome bits that hook onto the body's frankenstein bolts). Mine came off and it sounded like someone was sending morse code from the boot.
Users browsing this forum: No registered users and 158 guests
