Brake lines compatibility '03NB to '94NA
Steampunk
Postby Steampunk » Wed Oct 24, 2007 4:43 pm
Does anyone know if the fittings, brackets, etc are the same, in other words will stainless steel brake lines from an 03 NB fit a 94 NA?
CT
Postby CT » Wed Oct 24, 2007 9:28 pm
Should fit OK.
zoomzoom
Vehicle: NA6 - Turbo
Postby zoomzoom » Thu Oct 25, 2007 1:28 pm
Should be the same, only difference from memory is you use front ones on opposite sides. I have NBB brakes on my na and I compared the lines when I put them on, the only reason I didn't use the origional ones is the new brakes came with lines so I used them as they were newer.
Tim
Steampunk
Postby Steampunk » Thu Oct 25, 2007 3:12 pm
Thanks fellas. CT: have you used SS lines? If so, is there a tangible difference?
CT
Postby CT » Thu Oct 25, 2007 3:58 pm
1red5 wrote:Thanks fellas. CT: have you used SS lines? If so, is there a tangible difference?
All my cars have braided lines - road and race. It helps to promote a reliable pedal.
Matty
Postby Matty » Thu Oct 25, 2007 6:19 pm
zoomzoom wrote:Should be the same, only difference from memory is you use front ones on opposite sides. I have NBB brakes on my na and I compared the lines when I put them on, the only reason I didn't use the origional ones is the new brakes came with lines so I used them as they were newer.
Tim
ONLY the 1.6 has the brakes pivot in the opposite direction.
NA8A and NB8A brakes are identical, NB8B brakes are larger (brackets, pads and rotors are different) but the hoses will be the same.
Braided hoses are good.
