99MXV wrote:MX5-SP wrote:Well, If you drive the SP correctly, the smoke should always be behind you...
If you drove an SP correctly, I believe the ROOF should point UP
...in most instances, yes.
Marador wrote:Spy... about how long will it take to drive back to brisbane cbd from the end point ?
jules wrote:I believe I am in for this one.
Jules
Boags'MX5 wrote:Coolant has decided to play games on the OUTSIDE of the cooling system. I'll do a little investigating on Sat and hopefully we'll still be there. It looks like a hose; so shouldn't be a major drama.
Boags![]()
NMX516 wrote:Boags'MX5 wrote:Coolant has decided to play games on the OUTSIDE of the cooling system. I'll do a little investigating on Sat and hopefully we'll still be there. It looks like a hose; so shouldn't be a major drama.
Boags![]()
Gimme a yell if you need a hand.I meant to mention that the other night
sabretooth wrote:Mr Darby, do you still have any mats set aside for me? If so, is another Brisbanite willing to pick them up for me?
NMX516 wrote:Hi Andrew,
Could I get a set of those mats too, if there are any still available?
sabre, happy to bring a set back for you.
Gerard
