Alignment specs anyone?
Jimmy
Postby Jimmy » Mon Sep 03, 2007 6:06 pm
Am getting a new wheel alignment tomorrow as the front right lower control arm decided to loosen up suddenly and drop 15mm, completely throwing off the wheel alignment and making me dart all over the road. Im after some wheel alignment specs (camber, caster, toe) given that the front right is only able to achieve a max of -0.5degree camber. Ive had a search in the tech archieve and on miatanet but the closest i could find was a -0.75 camber on the front. So if anyone can fill in the blanks below that would be great, and maybe a comment about how you found it. I know its all about persoanly preference but i wouldnt mind something to work off and go from there.
Thanks,
Jimmy
Front:
Camber: -0.5
Caster:
Toe:
Rear
Camber:
Toe:
bigdog
King of the kennel
Postby bigdog » Mon Sep 03, 2007 6:14 pm
Check the tech archive on this forum Jimmy, the specs are all there.
As to your specific question you will need to fix whatever is bent or broken first then do the alignment - if you can only adjust to - .5 camber then something is wrong....
Boags
Postby Boags » Mon Sep 03, 2007 6:14 pm
How exactly did your control arm drop 15mm? :shock: And why can't you fix it and run normal camber?
Jimmy
Postby Jimmy » Mon Sep 03, 2007 6:20 pm
well it should look like this (front left):
and this is the front right:
I enjoy spirited driving and want to maximise it with a good alignment.
Jimmy
Postby Jimmy » Mon Sep 03, 2007 6:24 pm
Thanks bigdog but there isnt anything on there for a -0.5 front camber (this is the most negative mine can go so i have to work with it). The closest is a -0.75 which mine isnt capable of achieving :(
green_comet
Car Detailing Guru
Postby green_comet » Mon Sep 03, 2007 6:54 pm
Should fix whatever is wrong first, before you get an alignment. I got mine done the other day, running a little over -2.0 on the fronts.
Jimmy
Postby Jimmy » Mon Sep 03, 2007 6:55 pm
Ill get it checked out tomorrow. The car has taken a light hit to the front right earlier in its life so this could be the underlying problem. What should i/they be checking and how much roughly to replace?
Upper control arm $$$
Lower control arm $$$
Anything else?
I have already replaced the front sway bar but not the end links.
irwin83r
Postby irwin83r » Mon Sep 03, 2007 11:10 pm
if your lucky (kinda lucky anyway) it might only be the camber adjusting pin thats dead..
basically that washer (that looks to have a crack on it) is held to that pin by a small kinda spline.. so that washer should be fixed more or less to that bolt head. so when you rotate that bolt head (with the nut loose) it spins the bolt in the hole and the offset washer rotates with it, the out side of that washer riding along that raised section on the lower arm causing it to push the lower arm in or out respectively.
if that washer is no longer fixed to the bolt head and is now spinning freely(or atleast not firmly fixed to the bolt) it will not push the lower arm out very well if at all..
new lower arm pins ar not cheap however.. i'd ring mania and get a set of second hand ones that are in better condition that the ones you have now.. and if worse comes to worse put a spot of weld on the bolt fixing the washer to it.
the only other thing i would put it down to is a collasped bush.. which would result in some clunky sounds and a funny unsteedy feeling...
but that crack in the washer... id put money on that being the issue
further more if you have taken it to someone to get an alignment with it like this and they havent picked up on this (if it turns out to be the problem) go to a new wheel alinger.. unless you like the people there as they either caused the problem and dont want to pay for it or dont know what they are doing
irwin83r
Postby irwin83r » Mon Sep 03, 2007 11:43 pm
wheel alignment wise..
what kind of driving do you do? and what do you want from your tyres? what tyres are you going to use?what suspension are you running? how are you going to inflict the most wear on your tyres??
the amount of camber you need really seems to relate to driving style and also majorly what tyres you are running...
for example on street rubber on a tight track max camber is prolly pretty good. but if you step up to semi slicks you will prolly find the out side of the tyre is wearing more than the inside and you need more again... meaning you will need either offset bushes or modified lower arms to get the extra camber so when the car rolls onto the out side tread patch it dosent roll past the maximum contact.. moment.
but if your basically just using it on the roads with a fair amount of hwy.. then keep the camber fairly modest to increase the tyre life..
for me.. its pretty easy as i only really worry about track as the car dosnt get much driving other than track and the odd blat here or there so... max caster then max camber, toe i have been running 0 rear and 2mm front but since the new rear sway bar its been taily and ive had to wind back the rear dampers to get some more grip there... i really need to pick more brains about what i should be running for the track as far as toe goes
Jimmy
Postby Jimmy » Tue Sep 04, 2007 12:06 am
Thanks for the reply irwin83r, much appreciated. Just checked the car again and its not a crack. It is actually a thin bit of rubber which would probably indicate the bush is rooted. (although i havent had any problems with steering or heard any noises until now) If these need replacing, do you reckon i just go with the super pro alignment kit?
Im taking the car to CarCo first thing tomoz to hopefully get a verdict.
Driving wise, im a fairly \"spirited\" driver. Living in Canberra really has its benefits with all the winding hilly roads just 5 min out of town. I like to go for a long blast whenever i can which usually ends up being once or twic a week. The rest is round town. Im currently using Yoko S-Drive on Au lightweight rims (15\"). The car is still on stock suspension (for the time being). As the tyres cost me close to $800, i wouldnt mind them lasting a while but i understand that my driving style will shorten their life span a lot.
Atm, i dont have the cash to do a lot of \"repairs\" to fix the alignment but it will happen by the end of year. In the mean time, the car steers fine and tyre wear is even with my current alignment but was hoping for some proven figures for my camber limit.
Heres my current alignment. Want to change it coz its way to twitchy for my liking. Although, having said that it was loads of fun on the track with very average tyes! Im looking at bringing the rear camber down to just under -1. Thoughts?
Front
Camber: -0.4
Caster: +5
Toe: 0.15
Rear
Camber: -1.5
Toe: 0.35
Jimmy
Postby Jimmy » Thu Sep 06, 2007 7:04 pm
Well, i got them to check to see if anything was bent/isnt how it should be and got them to compare to good parts borrowed from carco. They compared everything and nothing was bent/broken. Obvisouly my issue still sucks so an alignment kit will be going in later in the year to get the camber i want.
irwin83r
Postby irwin83r » Sat Sep 08, 2007 2:05 am
JimmyJ5 wrote:Well, i got them to check to see if anything was bent/isnt how it should be and got them to compare to good parts borrowed from carco. They compared everything and nothing was bent/broken. Obvisouly my issue still sucks so an alignment kit will be going in later in the year to get the camber i want.
remember as everyone keeps pointing out if you are going to lower the car in the future you will get more camber from that also. you prolly wont need offset bushes if your not going to run semi slick tyres
Steampunk
Postby Steampunk » Wed Oct 17, 2007 11:46 am
Sorry to resurrect an old post but my 2 cents:
I found these on the Miata.net forum. The guy knows what he is doing as he goes into great detail about spending a whole day or so, changing one parameter at a time. Below are his recommendations for \"spirited\" to \"slightly aggressive\" road driving;
Here are my 1994 Miata's current alignment specs:
Rear
Toe: 1/32 inch (0°4.5' or 0.075°) IN per side
Camber: -1.75 degrees
Front
Camber: -1.2 degrees
Caster: 5.0 degrees
Toe: 1/32 inch IN per side
I had Fulcrum in Brisbane do this for me but with -1.70 and -1.1 Rear/Front camber. Works a treat with stock suspension bits.
There was a tangible difference ... but that is only cause the alignment pre realignment was WAY off on 3 out of 4 corners
Caffeine
Postby Caffeine » Wed Oct 17, 2007 12:46 pm
I have my car set as follows:
Front:
Toe : zero
Camber : -0.5 degrees
Caster : Max possible (usually around 5)
Rear:
Camber : -1.0 degrees
Toe : Zero (Many people like to run some toe in to avoid oversteer but I've never had a problem)
Those settings will be fine for street driving, and occasional track use. I set my fastest laps with these settings so they can't be that bad...
Hellmun
Postby Hellmun » Wed Oct 17, 2007 7:25 pm
Front:
1.3 degree negative camber(max)
6 degree castor(max)
0 Toe
Rear
2.5 degrees neg camber(Max)
0 Toe
This is barely lowered on standard bushes. Track settings but I guess we'll see how it go next trackday....
