offset question
- 16bit
offset question
can anyone tell me the difference between the A, B and C offsets in this chart? is it just from different points like before the centre piece and after it?
http://www.perfectrun.com.au/performanc ... Cface1.htm
btw would getting the 17 x 8 with plus 16 offset with 245/40/17 on the rear and 17 x 7 with plus 22 offset with 215/40/17 on the front need guard rolling? also do you think it would destroy the handling of just make it less likley to slide?
- Charlie Brown
Not sure what the difference is between A, B & C but you need atleast the +42 or +50 offset. Read up on \"bump steer\" before heading to the offset area you're thinking of. Also with the offset you are suggesting you would need to roll the front and do even more on the rear guards.
As for rim width, unless you have an NB8B or later the 8\" rim is illegal to run on the road. You can only go up 1\" in diameter and up 1\" in width and increase your track by 1\" (25mm) legally.
- 16bit
this is part of the nopro arches grand plan so there will be ample room under the arches - however the legallity bit does seem a problem. might have to stick with these and see if i can get away with them.
http://www.perfectrun.com.au/performanc ... ngGT-N.htm
in 17 x 7 with the plus 25 offset and the gun metal centre.
- godfather of saké
The A, B and C face thing is actually pretty important to nail down to make sure you get the look that you were after in your mind's eye.
One is the more \"dished\". It's not just a matter of actual offset, but also appearance. I can't remember which is which, but one extreme (either A or C) will curve outwards to make room for big calipers, so if you want a dished look with flat spokes you need to get the other extreme.
If you choose wrongly, you can end up with wheels that are actually quite low offset (and hence stick out a lot) but stock looking appearance with no dish to the spokes and miles of air between the spokes and the actual calipers.
There is a diagram in the catalog explaining this but I can't seem to find it on the website: www.rayswheels.co.jp
And oh BTW, 7in +25 will leave a set of Nopro flares looking a little undernourished
You'd need to start at around a zero offset if you were after the big flares
- AB7
Babalouie wrote:And oh BTW, 7in +25 will leave a set of Nopro flares looking a little undernourishedYou'd need to start at around a zero offset if you were after the big flares
Very good point, Zero Offset with flares. Looks just right
- godfather of saké
16bit wrote:shite - they look great! where are those arches from? hmm - so zero offset with new arches or +25 with rolled arches.
This is +7 offset with a 14x7 rim, and on an NA, that's how far you have to go to get the rim to be flush with the wheelarch. A +25 offset would be almost a full inch further into the 'guards
- 16bit
- 16bit
ok i have gone back to the drawing board and figured this out.
The stock wheels are 15 x 6 +40 offset and tyres are 195/50/15. The arches i would like to put on will be 40mm wider at the front and 50mm wider at the rear. Obviously i would like fill these.
I have calculated that if i get a 15 x 7 inch rim with a
+ 27 offset on the rear with a 20mm spacer it will be 46mm wider at the outside edge then standard (4mm clearance) and 18mm more (taking into account the 20mm spacer) clearance on the inside edge
+ 35 offset on the front with a 20mm spacer it will be 38mm wider at the outside edge then standard (2mm clearance) and a 12mm more (taking into account the 20mm spacer) clearance on the inside edge
My question is how much will the handling be effected and will you be able to align/setup the suspension so it works well or will this completely ruin the handling? I understand that with a wider stance i will probably tend to feel more stable/understeer.
I have Tein SS coil overs and all other bits are stock at the moment if that helps.
- AB7
I don't think you'll be filling 40mm front flares with a 7 +27 with 20mm spacers if the NB is anything like a NA, a 7 +17 doesnt quite get to the outer edge of the guards on a NA and you're effectively going for 7 +7.
Maybe look at getting those rims the USA guys use that come in 8 +0, they're cheap Chinese stuff but theyre about the best way to get low offset 4x100 rims at a cheapish price
- 16bit
Adam_NAclubman wrote:I don't think you'll be filling 40mm front flares with a 7 +27 with 20mm spacers if the NB is anything like a NA, a 7 +17 doesnt quite get to the outer edge of the guards on a NA and you're effectively going for 7 +7.
I am not interested in the cheap rims - i would rather pay more to get good stuff but thats not the point
If i got from a 15 x 6 +40 to a 15 x 7 + 27 with 20mm space it is an extra 46 mm wider.
use this calculator and add 20mm for the spacer.
http://marksink.com/tire_wheel_offset/offset.html
now the question is will my handling be effected and if so will i be able to setup the suspension to reduce any negative effects.
I increased my track by 41mm a side with my P1's on my NA and it still wasn't quite at the edge of the stock guards with 195's, so unless the NB is set up from stock with the outer edge of the wheels closer to the guard than the NA was, you're not going to be filling the flares at all with what you're planning on getting.
My Buddyclubs plus a 20 or 25mm spacer would get you out there though
edit
Oh, and yeah it does have quite an effect, steering gets quite a bit heavier and on my car there was a weird point at about 1/2 to 3/4 lock where it would scrub wide as if it had lost grip until you either backed the steering off or put more lock on, but you only ever use that much lock on really tight corners. My Volks and Watanabes sit slightly further inboard than the P1's and don't seem to have the same problem
edit
