EPA notice - Updated 28/11/07
Bevan
Postby Bevan » Thu Aug 23, 2007 8:36 pm
:shock:
ampz
Vehicle: NA6 - Turbo
Postby ampz » Thu Aug 23, 2007 10:18 pm
This is going to be a killer!
SR20s are an awesome engine. You will have you work cut out. That said, it will not be overly difficult.
The later model ones run an electronic speed sensor. the early ones should run a cable dríven one. you may need to machine up a new cable gear to suit the mx5 speed cable (or go electronic).
Clubman = no ac or ps so you should be right there. Maybe house the stock mazda water temp sensor so your gague does't get binned. A tee on the nissan oil presurre sensor will get the mazda oil guage working.
The rest will have to be Nissan.
This is going to end up a Unicorn! 8)
Huh?
Blue94t
Postby Blue94t » Sun Aug 26, 2007 10:23 am
So I heard back from the engineer. Looks like I can use any SR20det as the ADR requirements did not change between 91 - 94. 91 being the first year the SR20det came out in rwd, 94 being the year of my car.
Time to start buying parts now.
Jake
Fatty
Postby Fatty » Sun Aug 26, 2007 10:35 am
this car is gonna be a monster ! :shock: :shock:
i can't wait to see it jake.
sprx3
Postby sprx3 » Mon Aug 27, 2007 1:33 am
bruce wrote:
13b turbo - capacity (turbo multiplication) rules it out, plus the motor has to be newer than the car. 12a turbo is legal but not worth it
I had a 12at that made 250rwkw, all day everyday on a very safe street tune ;) more then worth it........
there is another way some of extreme guys used to go
LPG !!
no adr's ;)
i would look at a 1uz or even a 2j on gas.....
NOW that would be a KILLER conversion
& 1uz'ds are much cheaper & make more power then a std sr ;) then you have the options of forced induction & being on gas adr's dont apply :D
in saying that you could even put your current setup on gas & you would have the epa cleared ;)
want to join the mazda car club of australia?, for more info please p.m me
green_comet
Car Detailing Guru
Postby green_comet » Mon Aug 27, 2007 2:16 pm
Hey Jake, an SR20det would be a great choice for an engine swap. I recon that you are better off going with the newest one you can find though, maybe a blacktop sr out of an s14, or from an s15 if your budget stretches that far..
Its going to cost you heaps to get setup and working right, but it will be worth it when its all legal and your making awesome power. If you ever need any help just gimme a call and ill come round.
When I used to play with AE86 toyotas years ago, a mate of mine had a sr20det in his. It used to go like a bat outa hell, and it never gave him problems.. I was soo jealous. :?
heres a pic for you..
Ryan
Blue94t
Postby Blue94t » Mon Aug 27, 2007 2:45 pm
sprx3,
You obviously didn't read the thread :)
1UZ is out, requires heaps more engineering (torsional stiffness test of the chassis) and will cost heaps once a suitable manual gearbox was fitted up.
2J, too big and heavy. I still want the car to handle.
As for LPG, I am building a sports car not playing around with a bbq :D
I have used LPG before and it's not for this project. I want to do some tarmac rally's and don't know how CAMS would view the whole LPG thing.
The only gas I use is the laughing variety.
Ryan,
S13 is the way to go. Looking to spend less on the motor initially and put the change in to forged pistons and rods. The S13 motor has a better head design without the vvt. I would rather not run the vvt as it makes cam upgrades and other head work a lot more expensive. My bro has a S14 SR in his 1600.
That Sprinter looks neat.
You are right it won't be cheap, but the main expense is purchasing all the parts. Putting it all together and making it work is the cheap bit. I think it will be well worth it in the end. I will let you know if I need a hand, the offer is appreciated.
Jake
mossy
Postby mossy » Mon Aug 27, 2007 7:27 pm
Its a pity about the v8, would of been great to see one in a 5. I'm sure the SR20 will work out great though and since your in Melbourne it will be easy to head out to a track day and take a look at the work, maybe it will change my mind about a V8 240Z :mrgreen:
PASHN8
Postby PASHN8 » Fri Sep 07, 2007 1:57 am
Alright Jakey, please let me know once the conversion is all done and finished, and I will buy the completed car off you :)
I miss mine :(
- 2005 MX-5 SE
http://www.dinography.com.au - From the ground
http://www.skysight.com.au - From the air
Blue94t
Postby Blue94t » Fri Sep 07, 2007 9:48 am
Hey Dino,
looks like we will be building at least two SRx5's at this stage. I won't sell you mine, but you are welcome to come for a ride.
Jake
btw, you still looking for a photographer to work with you? pm me if you are
jules
Guitar Hero
Postby jules » Fri Sep 21, 2007 1:44 pm
Any update??
Jules
Blue94t
Postby Blue94t » Fri Sep 21, 2007 6:16 pm
The rego on the car is now suspended.
I have been working closely with my engineer and am in discussion with Speedworks at the moment regarding the best way to go about mounting the engine/box while still maintaining the clearance required by the engineer.
The pile of parts is also growing. Hopefully I will have a front cut in the next week or so. Then it is time to prep the engine/box, probably with some choice upgrades at the same time.
Jake
Blue94t
Postby Blue94t » Mon Oct 15, 2007 10:58 pm
To update the progress so far.
My S13 front cut has arrived. I picked up a 180SX front cut with ~80,000kms on it. It compression tested at 150,150,150,145. Oil pressure is good and it appears to have been well looked after.
In fact everyone who has seen it says it is the best condition front cut they have seen.
On Saturday I stripped the front cut of everything I need and all the bits I plan on selling to recup a bit of the cost of the conversion.
It all came apart very easily, the whole thing was stripped in about 4 hours.
The plan is to get the car together and engineered, get the epa notice cleared and then the mods begin.
Once I start stripping the car to begin the conversion I will start another thread with pics and details of the work done. I am competing in the 6hr Relay at Winton on the 28/10 so currently plans are to start after that. The car has to be ready for Phillip Island on the 16/12 so time will be tight.
Jake
green_comet
Car Detailing Guru
Postby green_comet » Mon Oct 15, 2007 11:11 pm
ooooo...sounds awesome.
Remember Jake if you need an extra pair of hands, just gimme a buzz..
I cant wait to see this all finished. :mrgreen:
jules
Guitar Hero
Postby jules » Mon Oct 15, 2007 11:48 pm
This is the first time I wish I lived in Melbourne :mrgreen:
Jules
