AVO KIT & A/C
mossy
AVO KIT & A/C
Postby mossy » Tue Oct 09, 2007 6:17 pm
Can a/c be hooked up with an Avo kit on a 1.6?
Fatty
Postby Fatty » Tue Oct 09, 2007 6:29 pm
before i bought the old avo kit, i visited avo and asked them if the current kit fits with the aircon. they said yes.
even the old one i got from you will work, i just need to put a clip on it , or something, to hold one of the pipes slightly higher as it fouls on the belt that drives the aircon compressor. i just haven;t got around to doing it yet. it only needs to move up about 2 or 3 cm, easy to do.
Sean
Postby Sean » Tue Oct 09, 2007 10:48 pm
Yeah, Mania confirmed it was possible on my old style AVO set-up too. I beelive they have done a few.
lowmiata
Postby lowmiata » Wed Oct 10, 2007 2:10 pm
I beg to differ alittle
On mine I had to modify the water outlet pipe ie shorten it along the block as it fouled the turbo front housing
thus in turn then fouled the back of the air con compressor
(which i didn't know) until i put the air con back on 6 months later
I probably could have rerouted the water pipe underneath the aircon but at the time I didn't know/take into consideration the air con comp. mounting
EVI15 1998 to 2008
mossy
Postby mossy » Wed Oct 10, 2007 5:38 pm
I modified the water outlet pipe when i put the new kit on so it clears the housing now, the reason for the a/c question is a potential buyer wants a/c on the car so I'll let them know, thanks.
Sean
Postby Sean » Wed Oct 10, 2007 5:46 pm
lowmiata wrote:I beg to differ alittle
Interesting, I didn't have a modified water outlet, just the stock one (runs close to the turbo). Perhaps that's why it can be done on mine?
jules
Guitar Hero
Postby jules » Wed Oct 10, 2007 5:54 pm
Good luck with the potential sale!
Jules
Fatty
Postby Fatty » Wed Oct 10, 2007 6:54 pm
yeah i'd heard of people having problems with that water pipe but i had no dramas. everything fit just fine. i guess mazda must have used slightly different pipes on some cars, for whatever reason :?
Miata Bart
Postby Miata Bart » Thu Oct 11, 2007 12:17 am
Sean wrote:Yeah, Mania confirmed it was possible on my old style AVO set-up too. I beelive they have done a few.
I had the a/c fitted by the Maniacs yesterday & its getting gassed up on the morrow. :D
Still having more fun than a barrel of monkies. :mrgreen:
lowmiata
Postby lowmiata » Thu Oct 11, 2007 1:39 pm
there is two different water pipes one effects everything the other doesn't
my guess is AVO made it to suit the one that fits everything
and then realised that there is some that don't fit
i think up to mid 90 had the long pipe after that it was shortned
but I cant confirm that
EVI15 1998 to 2008
