blackster wrote:The Pupat wrote:Looks fine to me.
I reckon you need to learn more about tuning cars before commenting on others ability.
I dont claim to be an expert, far from it. I think i have tinkered around with my car enough with the aid of haltech and seen other SE's to know what works and what doesnt.
13's isn't lean.
12-13 is acceptable for a turbo car (you can go leaner again if you want and NA it's normally accepted anything up to high 13's is acceptable).
You'll find that the leanness in the start of the chart is from lowish throttle input as they are ramping the car up. On a dyno with a turbo car you have to have the turbo spooled when you hit it otherwise it won't work properly. The little spike and the end of the graph would be from backing off. The map looks alright for an interceptor which is always going to be a bodge job compared to completely retuning the car.
