6x9's anyone?
Postby Okibi » Wed Aug 29, 2007 2:28 am
I had 6x9's in my parcel shelf but replaced with with 8\" 3 ways (much much much better)
Put some 8\" speakers in the doors first, then work on rear speakers if you can be bothered.
marcusus
Postby marcusus » Wed Aug 29, 2007 7:39 pm
I'm going to try and parcel shelf my 6x9's at the next Sydney dodgy day (pending hangover from a mates' buck's night the night before). Currently my 6x9's are sitting in the boxes in the boot, which is from my old car.
Alex
Postby Alex » Wed Aug 29, 2007 7:56 pm
I did but u lose a bit of room depending on if you have a rollbar or not, without a rollbar i'm sure you could make something similar to mine that sits further back
AJ
Postby AJ » Wed Aug 29, 2007 8:14 pm
that's a neat job! 8)
XMX5 Rogues
marcusus
Postby marcusus » Wed Aug 29, 2007 8:20 pm
If you could be bothered rebuilding it, you could even try and put it behind the BD bar. That way you could secure it to the bar itself so you wouldn't need that strappy thing.
Alex
Postby Alex » Wed Aug 29, 2007 10:23 pm
if i put it behind the BD bar then I wouldn't be able to put the top down because that needs about 9cm clearance from the BD bar, I already looked into this
marcusus
Postby marcusus » Wed Aug 29, 2007 11:22 pm
SM wrote:if i put it behind the BD bar then I wouldn't be able to put the top down because that needs about 9cm clearance from the BD bar, I already looked into this
Bugger eh? Oh well. Still tidy nonetheless. After seeing this windblocker and your fibreglassing work in the boot, I really wanna check out the audio in your car now :P
You going to be at the Mania dyno day?
Ajay
Postby Ajay » Mon Oct 08, 2007 4:18 pm
bringing alive a dead thread.. i would love to do something like this :)
wish i didnt have a glass window softop for moments like these :D
Bevan
Postby Bevan » Mon Oct 08, 2007 4:37 pm
mx5_boy wrote:bringing alive a dead thread.. i would love to do something like this :)
That wouldn't be worth any amount of time, let alone the amount it would actually take. You'd only hear bass. Everything else would just fire into the air, especially with your seats blocking the direct line between the speakers and your ears.
Ajay
Postby Ajay » Mon Oct 08, 2007 6:09 pm
i just think it looks quite good with the built in style bars into the box
Postby Okibi » Mon Oct 08, 2007 6:52 pm
Why not put the bar to good use and fix some speakers to it
