final drive ratio
final drive ratio
i'm selecting between 2 ratios, i need to know the one that will give me the higher speed . this is for my tamiya eunos roadster
6.82:1 vs. 6.10:1
which of these gives me the higher top speed ? ? i think i know the answer but need to check with you guys as i have too many beers and the brain is playing tricks on me
6.82:1 vs. 6.10:1
- RobbieRat
- StanTheMan
excuse the ignorance......Final Drive is that refering to the Diff ratio or 5th gear in the the gearbox?
- StanTheMan
AJ wrote:they're talking remote control cars stan
yeah but it's still the same terminology
i believe final drive ratio refers to the ratios between 1 engine revolution and 1 wheel revolution.... errr...i think ?
Fatty wrote:yes true. this sports tuned motor should take care of that tho!
But if you fit a high kv (rpms per volt) motor you may need a lower final drive to allow it to work efficiently. I fly RC planes and have recently got into electrics - lordy lordy things have come a long way since powered gliders with 1200 mA 7.2v NiCd packs and 540 brushed motors would struggle around for 2 mins of power runs.
With the planes I've got a couple of low kv brushless motors to allow direct drive props (high kv require a gearbox to spin a reasonable sized prop at an effective speed), coupled with lipo batteries I easily get 2 x 10 minute flights between charges flying hot little aerobatic or warbird craft.
- Benny
If you have a hot motor, a numerically lower gear may actually mean that the car goes slower, and not faster!
It has to do with the torque of an electric motor .
Generally, the hotter the motor, and the more it revs, the lower its torque is, so it may not be able to comfortably pull the lower gearing.
The lower gearing will also mean a shorter run time, as the motor needs to draw more current (which causes more heat) to pull the taller gearing.
Having a taller gear will also hurt your acceleration.
If you want to go fast, get a brushless motor for it, which will probably blow the diff, but it will certainly go, especially if you run it on Li-Po batteries.
I believe that the world record for a brushless R/C car is over 250km/h and even a standard brushless motor can get most R/C cars to go over 160km/h!
I used to have a petrol powered on-road R/C car ( an Italian made Serpent with a hot Nova Rossi engine) that could pull 130km/h in top gear (2-speed auto box on that one), and that was very difficult to control at those speeds, but it would out accelerate my friends hot HSV up to about 300M.
