Can you possibly advise what sort of clutch is it that I bought from you?
The Exceede HD one (it's a pinkish coloured alloy frame)
Calling Sheck
- Uncle Arthur
- Dodgy Award Benefactor
- Location: Doesn't matter where I'm from-it's that your daughter is with me that's the biggest concern :D
Calling Sheck
- Uncle Arthur
- Sean
Sheck wrote:It is an eXtreme clutches clutch, HeavyDuty with organic disk.
Bought from a place in adelaide as it was cheaper to post it from there than buy it from a workshop here.
Hope that helps!
Dave
I put an extreme 4 paddle into my turbo mx5 (now miata barts).
Can't fault it.
- Uncle Arthur
Sheck wrote:so did i, but with an exta heavy duty pressure plate.
the organic started letting go at 10psi on the old TD04
I'm running 8-9psi - no probs as yet. But I'm also not putting it under drift strain and very few (actually none) hard launches.
heheh yea good old drift!!! but actually i had it letting go just on acceleration once i was up in the higher revs like around 5-6krpm.
I do have cams but i doubt i was making much power prolly around 150hp atw as my tune with the rb20 turbo (which felt the same as the td04) was at 155 but had a little pinging in one spot (comming onto boost).
Oh my car will be back at the tuners this comming week, so i'll definately post up the results. Hoping for 180-200hp, and hopefully that'll be able to smoke the 17's i'll be fitting to the rear for drifing
Dave
Dave
