New Seats
Postby Okibi » Fri Sep 21, 2007 4:28 am
Very sexy.
I'm a big fan of the sparco roadster seats too.
Postby fastfreddygassit » Fri Sep 21, 2007 11:04 am
Andy.
Wow!
Those seats look amazing!
Well done. :mrgreen:
Postby bruce » Fri Sep 21, 2007 11:08 am
I've always liked that Bride seat - pure JDM.
Tell me Okibi, do you have any better pix of the above seats?
Andy Wana
Postby Andy Wana » Fri Sep 21, 2007 11:11 am
Thanks guys. I was contemplating to get a pair of Sparco Roadsters too before, but I read it somewhere that the side shoulder bolster will need to be shaved (hello angle grinder) a bit to fit into the cabin.
But really, Bride PROS is just on a different level altogether.
The craftsmanship is excellent and it fits like a glove in the 5.
I ♥ asymmetry
bigdog
King of the kennel
Postby bigdog » Fri Sep 21, 2007 7:35 pm
Okibi wrote:Another issue that I hadn't expected.
Because the seat is a bit higher and is wider around my shoulders it's now harder to reach behind me, flick the soft top over the brown davis and catch it with my other hand. :?
Wind drivers window down, reach out and back with your right arm and grab the frame edge and lift up - works a treat for the less vertically challenged driver 8)
marcusus
Postby marcusus » Fri Sep 21, 2007 7:36 pm
Does Bride have a website I can check out?
I figure if I want to upgrade seats I may as well go all out and get a set of race seats that are leather trim like yours.
What's the lumbar support like in those seats Andy? I should've really had a sit in your car at Mania, but was distracted by other random things at the time.
Caedrus
Postby Caedrus » Fri Sep 21, 2007 11:09 pm
Guys,
I am quite keen on getting some of Max's seat covers - but here is my question:
I have an SP. Are these the same seats as the NB8B / NB8A / SE, or what? I just want to make sure I order the right ones...
Thanks
C.
Postby sliq » Sat Sep 22, 2007 8:52 am
Caedrus wrote:I have an SP. Are these the same seats as the NB8B / NB8A / SE, or what? I just want to make sure I order the right ones...
if anything, it should be the same as any NB8B - only thing is i'm not too sure if max has the nb8b template to produce one for you caedrus
Andy Wana
Postby Andy Wana » Mon Sep 24, 2007 1:38 pm
marcusus wrote:Does Bride have a website I can check out?
I've not come across many Bride websites on the net
This is the site that I use to get more info on them
http://www.mx5cartalk.com/
Seat is not a comfortable as the OE seat (it is a steel framed, leather bucket seat), but it does hold you in place snugly and securely.
Getting in and out can be tricky at first, but I have no problems with it now.
Side bolsters and hip bolsters aren't as tall/wide as other seats out there, so it is liveable.
Shoulder area is a little small regardless of your frame, so you may find your back arching forward a little when driving.
I would invest in another form of lower back support if any long driving trips is in the agenda.
I only live 5km from work, so I have no problems with it. If you have to brave the mad commuting rush hour on a daily basis, I would recommend a recliner instead (or the Sparco Roadster 2s)
My 2 cents.
I ♥ asymmetry
hot rod
After new seats
Postby hot rod » Mon Sep 24, 2007 7:25 pm
I'm looking for new seats atm for my NA.
The SE seats look nice and although I've never sat in one, they don't look like they offer the support of say a Recaro. I'd prefer to stick with a Mazda option as they are easy to fit but has anyone found another solution, i.e like a Recaro from an EVO or even possibly an RX8 seat?
I would like to be able to run a harness so would prefer holes in them to run through, i.e Honda sepc Recaro's.
The Bride seats look great but I'd probably go a recliner version ($$). Any more suggestions guys?
I'm looking at getting some in on a container so a factory fitted seat will work out quite cheap if a suitable solution can be sourced.
marcusus
Postby marcusus » Mon Sep 24, 2007 8:45 pm
Hmmm... Maybe recliners are the way to go.
But then again, it'd probably be cheap enough to just add some padding to the NB8A seats if I get them retrimmed in leather.
I think I just need to sit in other people's cars more :P
Andy Wana
Re: After new seats
Postby Andy Wana » Mon Sep 24, 2007 9:54 pm
hot rod wrote:I'm looking for new seats atm for my NA.
I would think that the RX8/Evo seat would be too wide and big for the MX5.
The seat can't be wider than 21' across from memory. Got this figure from Kelvin (Eggbox)
I ♥ asymmetry
Andy Wana
Postby Andy Wana » Mon Sep 24, 2007 9:56 pm
marcusus wrote:Hmmm... Maybe recliners are the way to go.
Go for the NB8B seats I'd say, they look sexy.
I ♥ asymmetry
marcusus
Postby marcusus » Mon Sep 24, 2007 9:58 pm
Andy Wana wrote:Go for the NB8B seats I'd say, they look sexy.
mmm... Might just have to wait for a cheap set to come along, poach them, then get them retrimmed. It'd probably suit my purposes better.
timk
Postby timk » Mon Sep 24, 2007 10:22 pm
I love my Sparco Sprint but it takes two hands free to get in and out easily! :P
Users browsing this forum: No registered users and 150 guests
