anyone bored out a 1.8 to a 2.0ltr?
Woo
Vehicle: 10AE - Turbo
Postby Woo » Sun Sep 23, 2007 11:11 am
True ZoomZoom, must remember to not post whilst drinking :idea:
We're running 86 mm pistons in sleeves
Very slightly modified 10AE #2562 ..... one of 149 in Australia :wink:
Race what you brung ..... And hope you brung enough
marcusus
Postby marcusus » Sun Sep 23, 2007 4:21 pm
Sean wrote:Depends... If you just want to stab 200kw on teh dyno, then drive it daily you wont have an issue on s tock engine, it has been done by at least 2 forum members, but if you want to have 200kw and use all 200kw regularly you are not going to be keeping stock engines long.
??? Can you elaborate on how this was done? It doesn't sound plausible to me, but I'm happy to be corrected.
Sean
Postby Sean » Sun Sep 23, 2007 5:50 pm
Car 1
AVO manifold, gt2871R (had small front housing not the 4 inch one), 540cc injectors, walbro pump, AVO cooler pipes, custom cooler, custom dump pipe microtech ecu, extrudehoned intake manifold, stock head/bottom end.
Car 2
AVO manifold, Garrett T28 based turbo (cannot be sure of exact specs but internal gat T28 flange, big 0.7 ar front, .86 rear) 600cc injectors, link plus, custom dump pipe, AVO cooler and pipes, all stock internal head and bottom end.
Both made between 200-210rwkw.
Car one was daily dríven, but generally on 10-12psi where it only made about 170kw.
Car two was also daily dríven, and dríven a lot harder, cooked a few stock bottom ends before the owner opted to build an engine rather than justkeep replacing them.
Interstingly they were breaking in teh middle of the rev range, I suspect it was peak torque breaking them, not peak power.
Fairly sure Tyrone (Drift fury on here) also saw over 200rwkw from his 1.6 turbo on stock internals, he was using a fancy twin wastgated subaru turbo IIRC.
zoomzoom
Vehicle: NA6 - Turbo
Postby zoomzoom » Sun Sep 23, 2007 6:34 pm
Woo wrote:True ZoomZoom, must remember to not post whilst drinking :idea:
I understand, I too suffer from that occasionally :D
marcusus
Postby marcusus » Sun Sep 23, 2007 7:37 pm
Sean wrote:Car 1
Car 2
Right, so they weren't really what I'd consider a stock engine. Although the engines themselves were stock, modifications had been done to increase performance.
Was starting to wonder whether it was possible to have (my definition of) a stock engine pulling that much power...
Sean
Postby Sean » Sun Sep 23, 2007 7:54 pm
marcusus wrote:
Sean wrote:Car 1
Car 2
LOL, perhaps internally stock was more appropriate.
