NB8A Engine (head) Question
- JBT
Does the NB8A engine have a CAS at the rear of the exhaust cam and associated \"O\" ring oil seal as per the NA8
The parts diagram I have indicates there is just an oil seal cap there. It's not a good diagram though.
- rhysk
- Bevan
- Bevan
- Matty
JBT wrote:Thanks. Yes, I know about the CPS at the front, my question is what is at the rear of the exhaust camIs it just a blanking seal
There is a blanking plate. You need to remove the last cam cap to remove it. Not sure if there's an o-ring on it, but a CAS will fit in, so probably... The cam still has the dog drive for a CAS too.
photo on page 46
- Bevan
OOoooh, sorry, I know what you'r asking now. Matty is right, there is a blanking plate there. You can retrofit an NA8 CAS into that spot. This way, you can disconnect the VVT part of the engine and control engine timing with a piggy back that doesn't know how to control the MX5's VVT.JBT wrote:Thanks. Yes, I know about the CPS at the front, my question is what is at the rear of the exhaust camIs it just a blanking seal
Photo anyone
That's how I learnt what is in that spot anyway.
