NB8A Engine (head) Question
JBT
Postby JBT » Thu Sep 20, 2007 10:15 am
Does the NB8A engine have a CAS at the rear of the exhaust cam and associated \"O\" ring oil seal as per the NA8 :?: The parts diagram I have indicates there is just an oil seal cap there. It's not a good diagram though.
rhysk
Vehicle: NB8A - Supercharged
Postby rhysk » Thu Sep 20, 2007 10:46 am
No, it is at the front.
supercharged NB (in Brisbane) - qr 1:01:75 (s), 1:05.90 (c)
jaguar xjr supercharged v8
Bevan
Postby Bevan » Thu Sep 20, 2007 10:52 am
rhysk wrote:No, it is at the front.
Bevan
Postby Bevan » Thu Sep 20, 2007 11:00 am
Crankshaft Position Sensor is number 6. 8)
JBT
Postby JBT » Thu Sep 20, 2007 11:02 am
Thanks. Yes, I know about the CPS at the front, my question is what is at the rear of the exhaust cam :?: Is it just a blanking seal :?: Photo anyone :?:
Matty
Postby Matty » Thu Sep 20, 2007 11:14 am
JBT wrote:Thanks. Yes, I know about the CPS at the front, my question is what is at the rear of the exhaust cam :?: Is it just a blanking seal :?:
There is a blanking plate. You need to remove the last cam cap to remove it. Not sure if there's an o-ring on it, but a CAS will fit in, so probably... The cam still has the dog drive for a CAS too.
photo on page 46
Bevan
Postby Bevan » Thu Sep 20, 2007 11:32 am
JBT wrote:Thanks. Yes, I know about the CPS at the front, my question is what is at the rear of the exhaust cam :?: Is it just a blanking seal :?: Photo anyone :?:
OOoooh, sorry, I know what you'r asking now. Matty is right, there is a blanking plate there. You can retrofit an NA8 CAS into that spot. This way, you can disconnect the VVT part of the engine and control engine timing with a piggy back that doesn't know how to control the MX5's VVT.
That's how I learnt what is in that spot anyway.
JBT
Postby JBT » Thu Sep 20, 2007 2:14 pm
Okay, thanks folks. I guess in its NB8A guise then it isn't a potential oil leak source like the NA6/NA8 CAS \"O\" ring can be. Cheers. :)
