GROUP BUY - Number Plate Bracket: Front or Side Mount NA/NB
Its on
Thank You
Tools required - 10mm wring spanner
Time Taken - 10 minutes
For NSW Plates you may find that you have to drill two new holes in your plate at the bottom. Its worth just spending the extra couple of minutes getting the holes in the right spot. I fitted the first nut then lined up the second one with the plate attached.
Is it just my imagination - feels like I have picked up about 20 extra Kws and fuel use has halved since installing this 15 minutes ago
Thanks Boags
Thank You
Thanks Boags
- timk
- Brett_MX5
- Boags
Excellent!
Pedrok, more info on having to drill new holes please! It should bolt straight on, why doesn't your plate have holes down the bottom? Pics please.
Boags
Boags
- MasterZ
- Vehicle: NA6 - Turbo
came home today from tafe and found the item had arrived and leaning against the door along with my new springs, like they said 10 minutes later there on, thanks Boags. really appreciate it
1992 Mazda MX5 Turbo | 2004 VW Golf GTI | 2010.5 VW R36 Passat Wagon | 1985 Mazda HBES 929 13b Turbo | 1987 Mazda RX7 FC3S Turbo | KE20 Corolla Coupe
- sliq
Boags'MX5 wrote:Excellent!
Boags
the slim NSW plates only have holes at the top, nada down the bottom of the car plate. unless you want half your plates blocking air coming into ur radiator
- Bevan
Boags
As Sig said my thin NSW plates only have holes at the top. Only takes a minute to sort out.
Agree about the marks left by the old ones - I raised this at my last service and service centre tooks pics for Mazda. Waiting a response. Will post response here here I get it
- Alex
Got mine as well, not sure when I'll have time to put it on
my old one left heaps of marks from previous owner on the front bar, but then someone ran into me and it got replaced, probably not the best way to get 2 small dents fixed up
anyone got pics of side mount on NB ??
- bigdog
- King of the kennel
Users browsing this forum: No registered users and 58 guests
