GROUP BUY - Number Plate Bracket: Front or Side Mount NA/NB
pedrok
Postby pedrok » Mon Sep 03, 2007 12:48 pm
Its on :P
Thank You
Tools required - 10mm wring spanner
Time Taken - 10 minutes
For NSW Plates you may find that you have to drill two new holes in your plate at the bottom. Its worth just spending the extra couple of minutes getting the holes in the right spot. I fitted the first nut then lined up the second one with the plate attached.
Is it just my imagination - feels like I have picked up about 20 extra Kws and fuel use has halved since installing this 15 minutes ago :lol:
Thanks Boags
Jt-1600
Postby Jt-1600 » Mon Sep 03, 2007 2:27 pm
Just received standard bracket, looks impressive i must say, gotta wait till i get home to put it on now..
Cheers Boags....
timk
Postby timk » Mon Sep 03, 2007 2:52 pm
Put mine on yesterday, looks the shizzle! :P
Now I just have to touch up the scratches from the nuts behind the stocko plate holder. :frown:
Brett_MX5
Postby Brett_MX5 » Mon Sep 03, 2007 2:52 pm
Got mine today - thanks Boags :D
"You tried your best and failed miserably,
The lesson is, never try"
-Homer Simpson
Caedrus
Postby Caedrus » Mon Sep 03, 2007 3:06 pm
Holder arrived, 10 minutes later, plate on.
Quick, simple, easy. Many Thanks.
3 cheers for Boags!
C.
Boags
Postby Boags » Mon Sep 03, 2007 4:03 pm
Excellent!
Pedrok, more info on having to drill new holes please! :shock: It should bolt straight on, why doesn't your plate have holes down the bottom? Pics please.
Boags
MasterZ
Vehicle: NA6 - Turbo
Postby MasterZ » Mon Sep 03, 2007 4:20 pm
came home today from tafe and found the item had arrived and leaning against the door along with my new springs, like they said 10 minutes later there on, thanks Boags. really appreciate it :D
1992 Mazda MX5 Turbo | 2004 VW Golf GTI | 2010.5 VW R36 Passat Wagon | 1985 Mazda HBES 929 13b Turbo | 1987 Mazda RX7 FC3S Turbo | KE20 Corolla Coupe
Postby sliq » Mon Sep 03, 2007 4:55 pm
Boags'MX5 wrote:Excellent!
Boags
the slim NSW plates only have holes at the top, nada down the bottom of the car plate. unless you want half your plates blocking air coming into ur radiator :frown:
Bevan
Postby Bevan » Mon Sep 03, 2007 5:37 pm
Drill two holes in the top.
Or if the holes line up, just flip the bracket upsid-down.
Jimmy
Postby Jimmy » Mon Sep 03, 2007 5:48 pm
Recieved today and is now on the car. Thanks Boags, looks schmick 8)
pedrok
Postby pedrok » Mon Sep 03, 2007 5:49 pm
Boags
As Sig said my thin NSW plates only have holes at the top. Only takes a minute to sort out.
Agree about the marks left by the old ones - I raised this at my last service and service centre tooks pics for Mazda. Waiting a response. Will post response here here I get it
Alex
Postby Alex » Mon Sep 03, 2007 6:01 pm
Got mine as well, not sure when I'll have time to put it on
my old one left heaps of marks from previous owner on the front bar, but then someone ran into me and it got replaced, probably not the best way to get 2 small dents fixed up :P
anyone got pics of side mount on NB ??
bigdog
King of the kennel
Postby bigdog » Mon Sep 03, 2007 6:04 pm
Mine arrived today. Will polish then fit tonight :D Thanks Boagsy!
Postby Okibi » Mon Sep 03, 2007 6:18 pm
So where's all the photos?
Blue10
Postby Blue10 » Mon Sep 03, 2007 6:26 pm
Just installed mine today, installation was a breeze took about 10 min in total. :D , very pleased with results. Didn't have the issues as I have the standard large yellow NSW plates which have the holes on the bottom. Thanks Boags.
Users browsing this forum: No registered users and 71 guests
