WITHDRAWN
zoomzoom
Vehicle: NA6 - Turbo
Postby zoomzoom » Tue Dec 26, 2006 6:11 pm
mine had a squeak after doing a little suspension work, I recently changed the swaybars and greased all the bolts through the swaybar links. This seems to have fixed the problem. All I can suggest is to grease all those kinda bolts and also the shock bolts.
Mr_Q
Postby Mr_Q » Tue Dec 26, 2006 8:52 pm
I had a bad squeak on one corner of my '93 when I bought it earlier this year. I tried a few things (including regreasing the swaybar bits) but it didn't go away until I replaced the shocks and springs. I have a feeling it was the shock on that corner that was doing the squeaking.
Is your squeak just in one corner, or all over?
Mister Q
Had: Red 2004 SE, Red 1993 NA8 Clubman, Green 1991 NA6 LE
StanTheMan
Postby StanTheMan » Tue Aug 28, 2007 1:58 pm
Sell your car. :roll:
Bevan
Postby Bevan » Tue Aug 28, 2007 2:12 pm
mxv93c wrote:Does anyone have any solutions please
You have 2 suggestions...
Grease Sway and shock bolts
Replace suspension
Don't forget that your suspension is 14 years old now so it will need some sort of maintenance. I would start with the grease and then look at replacing your suspension.
Sweaking Suspension
Postby sliq » Fri Jun 12, 2009 1:04 pm
bump
Calling on the wisdomess of forumites.
I recently installed some height adjustable bilsteins in my NB8B. Prior to adjusting their heights, the shocks did not make any squeaks whatsoever.
But after playing around with the collars and lowering the car, there appears to be some squeaks when going over bumps and even flat surfaces. It is coming from the RHS of the car (front and rear)
When i tightened up the collars and rotated the springs a bit to make sure there was no dirt stuck between the shock and spring, the squeaks went away. But after 10 minutes of driving, the squeaks have returned, but they only squeak over bumps and not over flat surfaces anymore.
Where are the squeaks coming from, on the shocks? And more importantly, how do i get rid of them?
Steampunk
Sweaking Suspension
Postby Steampunk » Fri Jun 12, 2009 1:32 pm
Maybe your springs are rubbing together upon compression? or the rubber ontop of the spring perch has perished.
