Difficulty starting
meanmx
Difficulty starting
Postby meanmx » Fri Aug 03, 2007 10:15 pm
Hey guys, Just after some advice. My car has had trouble starting sometimes when it is warmed up. Had this problem since I got the car but it seems to be getting worse lately so I am getting of my arse at long last. I have changed the plugs and leads recently so that is the basics covered. What happens is that when hot sometimes (not all the time) the car will crank normally but wont fire up. Unless I get it a little petrol infusion via the go pedal. Then it will start up and idle roughly for the next 30-60 seconds and be back to normal. Looking for lots of ideas so I can trouble shoot tomorrow. Thanks guys
Ben
2014 VW Mk7 Golf R
Postby fastfreddygassit » Fri Aug 03, 2007 10:17 pm
have you tried changing your plugs and leads?
:mrgreen:
ampz
Vehicle: NA6 - Turbo
Postby ampz » Sat Aug 04, 2007 12:17 am
^^^ What he said :P
Have a look at the coil pack. Make sure the plug is in firmly and is free of any crap or corosion.
Check the ground near the back of the head and also the ground distribution block directly below the wiper motor.
I had accidentally left the ground block loose and had a bit of missing as well as difficult to start.
Huh?
Ajay
Postby Ajay » Sat Aug 04, 2007 12:52 am
yeah i think its your plugs or leads also :lol:
my car used too have the same symptoms.. however it went away after a few days...
sorry i cant be any help
meanmx
Postby meanmx » Fri Aug 17, 2007 1:20 pm
Just thought I might update this. I went round to my good friend Fastfreddy's the other week and we had a look into it. We changed the iridium sparkplugs out and put some Champion gold in. The old iridiums were still good although a little dirty. Changed the fuel filter which was badly overdue and we checked to make sure the leads were good. After all this I still have a problem so we thought it may be the battery so I changed that during the week for that new pulse brand but I am still having an issue so I am after anymore suggestions to fix this. Any help would be appreciated. Thanks guys
Ben
2014 VW Mk7 Golf R
Alf
Postby Alf » Sat Aug 18, 2007 9:17 pm
bdscott wrote:we checked to make sure the leads were good.
Yepp you've narrowed it down to the leads pretty much.
Alf
AJ
Postby AJ » Sat Aug 18, 2007 11:28 pm
concur..............when i see \"checked\" instead of \"replaced\" :lol:
XMX5 Rogues
meanmx
Postby meanmx » Sun Aug 19, 2007 1:26 am
Cmon fellas. The leads are less than a year old and they are good magnecore ones. Especially as it was doing it before I changed the leads and still doing it after. I need more out there suggestions as I have looked at all the basics already. Nice try though :D
Ben
2014 VW Mk7 Golf R
Postby fastfreddygassit » Sun Aug 19, 2007 3:41 am
what did i say about the answers :roll:
JBT
Re: Difficulty starting
Postby JBT » Sun Aug 19, 2007 6:43 am
bdscott wrote:What happens is that when hot sometimes (not all the time) the car will crank normally but wont fire up. Unless I get it a little petrol infusion via the go pedal. Then it will start up and idle roughly for the next 30-60 seconds and be back to normal.
I don't believe pumping the pedal during start will actually "infuse" fuel in an injected engine because there is lttle to no airflow and the fuel system is operating via the circuit operating relay on a 1600 until it starts. You have a 1600 engine don't you :?:
It could be an intermittent ciruit opening relay.
Maybe you have a dodgy injector or two or dodgy wiring to the injectors. Have you had them serviced?
Might also be a problem with the fuel pressure regulator.
Could also be an earth wire problem: from miata forum References are to a LHD car.
Please update us with your investigation results.
fastfreddygassit wrote:what did i say about the answers :roll:
Very unhelpful comment.
Woo
Vehicle: 10AE - Turbo
Postby Woo » Sun Aug 19, 2007 11:55 am
Not 100% sure if the 1.6 has a TPS but it sounds TPS related
Very slightly modified 10AE #2562 ..... one of 149 in Australia :wink:
Race what you brung ..... And hope you brung enough
ampz
Postby ampz » Sun Aug 19, 2007 4:04 pm
TPS on the 1.6 is an on/of/on switch indicating idle (on) cruise (off) and WOT (on).
If you also have an occasional 'miss' at idle as well as hard starting it will be a ground issue at either, the coils (back of the head) or the separate ignitor on the inside guard just in front of the brake booster.
Take off the grounds, rub them with wet/dry to make them shiny again, bolt back on.
Unless this has been done already, then ignore me. :)
Huh?
meanmx
Postby meanmx » Sun Aug 19, 2007 5:53 pm
Thanks for the suggestions guys. Very helpful and I will investigate them at the earliest opportunity. Anybody else have anything I should look at then please post it up. Any little bit of info helps
Ben
2014 VW Mk7 Golf R
funmx5
Postby funmx5 » Sat Feb 23, 2013 11:41 pm
anyone know about this one ???
red na6
cx7
Postby fastfreddygassit » Sun Feb 24, 2013 1:51 am
It was the leads.
