195's or 205's???
sabretooth
Postby sabretooth » Sun Aug 05, 2007 12:27 pm
JimmyJ5 wrote:Interesting point: The S-Drive is cheaper in the 205 compared to the 195. $10-$15 difference. How come?
Really? I was quoted otherwise. Anyway, I have 205/50/R15 S-Drives on my 15x7" rims. Very happy so far, but that's also going to be the new alignment also getting grins!
This is the second time I've gone for 205/50/R15s over 195/50/R15s - I just find that they look tons better. I personally think skinny tyres on wide rims looks really silly.
Interesting article regarding tyre contact patches, thanks!
Jimmy
Postby Jimmy » Tue Aug 07, 2007 10:00 am
Went to re-order the tyres today. Turns out that they only have two 195's in the country :shock: Next shipment is expected in a 1-2 months :( So, i went with my original order and got the 205's.
tk421
Postby tk421 » Tue Aug 07, 2007 10:41 pm
Gazbo wrote:
manga_blue wrote:I don't think you actually get a larger contact patch with a 205/50 over a 195/50. There's not enough weight in an MX5 to do that. You just get a different shaped patch instead, plus a little bit of additional tyre weight, plus some additional sidewall height and flex.
This is true. Have a look at this site for a good explanation:
http://www.carbibles.com/tyre_bible.html
(Actually page 2 http://www.carbibles.com/tyre_bible_pg2.html deals with tyre width)
This has to be one of the most useful posts I have read on the entire forum all year. Nice one!! :D :mrgreen:
You have just confirmed that 195 / 50 semi slicks on my factory 6 inch rims will suit just fine!
Steve
98 NB8A, Mania CAI, Eibachs and Bilsteins, Whiteline brace, Starcorp's, DBA Slotted and asstd bling, FM butterfly brace. FFS coldside and the whiiiinnne. Now 138rwkw (Glory Run :) ) More with tuning.
http://users.tpg.com.au/usethe4c/Green+Machine.jpg
Mr Starlet
Postby Mr Starlet » Thu Aug 16, 2007 4:45 pm
I run 215 all around, feels pretty good in dry and wet. For spirited stuff I'll lower pressure abit to increase effective contact area, tyres takes a little longer to warm up but once they do they're great. I find the wider tyres helps with understeer/oversteer, but at the same time weighs alittle more and so alittle less zippy. I might try stretching out my next set as I run 7\" front and 8\" back rims.
Users browsing this forum: No registered users and 378 guests
