Instrument cluster removal
robbiew
Postby robbiew » Tue Aug 07, 2007 8:47 pm
Hi all
have just aquired a lovely s/s instrument bezel (surround) and need info on how to remove dash etc to instal.
Tried a search but to no avail.
Any help greatly appreciated. For a 2002 NB8B
Robbiew
Bevan
Postby Bevan » Tue Aug 07, 2007 8:56 pm
1) Remove the 2 screws from the underside of the steering column shroud.
2) Seperate and remove steering coloumn shroud
3) Grad the \"hood\" of the instrument cluster and give it a few very firm tugs. After the initial \"pop\" remove the hood carefully
4) There are 4 screws that hold in the actual instrument cluster. Undo them and the cluster comes off.
This is as far as what i've needed to go. It seems there are many tabs around the cluster that need to be popped off to take the clear plastic face off.
Good luck and post pics!
Bevan :)
jules
Guitar Hero
Postby jules » Wed Aug 08, 2007 2:28 pm
Be very careful getting the clear plastic lens window off. Use a hairdryer if you need to. They can crack.
Jules
robbiew
instrument cluster
Postby robbiew » Wed Aug 08, 2007 7:45 pm
i bekieve that there are two types....one where the plastic cover is glued on and the other is attached by tangs....is the NB8B a \"tang\"version?
robbiew
Bevan
Re: instrument cluster
Postby Bevan » Wed Aug 08, 2007 7:50 pm
robbiew wrote:i bekieve that there are two types....one where the plastic cover is glued on and the other is attached by tangs....is the NB8B a "tang"version?
robbiew
Never heard of a tang before, but I think our cars have them (if you mean the plastic tabs).
It literally takes less than 5 minutes to do thos steps above so your best bet is to take it out and have a look yourself. :)
robbiew
Postby robbiew » Thu Aug 09, 2007 8:01 pm
robbiew
Thanks, Bevan
will have a go this weekend and let you know
with pics !!
ampz
Vehicle: NA6 - Turbo
Postby ampz » Sat Aug 11, 2007 10:28 pm
Bevan wrote:Never heard of tang before :)
Orange powder you stir a couple of teaspoons in a glass of water and add ice. :mrgreen:
Yum :P
Huh?
Bevan
Postby Bevan » Sun Aug 12, 2007 5:55 pm
Yum :P
:shock: That didn't come standard with MY car! I just got a shitty tasting coffee from the dealer! :lol:
Users browsing this forum: No registered users and 163 guests
