Bugger... cracked rear window
phaedo
Postby phaedo » Sun Aug 12, 2007 4:34 pm
Ok, did a bit of a search but that turned up nothing, anyway, I was putting the roof up and saw a big tear in the plastic rear window. Kinda my own fault, I had not been unzipping it properly, only half way - reason for that is the stitching in the passenger side corner when zipping it up around the bend seemed to be a bit loose, and I was concerned about that tearing. But now I have the new issue of a big hole in the back window. Is there somewhere I can get just a replacement window piece? The rest of the roof is fine, so I would prefer not to replace the whole thing, plus the cost of the new roof would be a lot more. Any ideas? Ideally I would like to put a glass window in, but I doubt that is going to work in the original type.
StanTheMan
Postby StanTheMan » Sun Aug 12, 2007 4:51 pm
You can...... but be aware standard top Has a differnt size zipper to the Robbins aftermarket.
The upholsterer in Brookvale will want to charge you around $400 for a new rear window. or $500 for a 2nd hand one completely fitted. in which case you may want to look for a ebay one.
you can try mania if they have any spare rear windows. Just check the size of the zipper.
phaedo
Postby phaedo » Sun Aug 12, 2007 5:01 pm
Looks like it could end up being just as cheap to get a new roof - found MX5 parts uk have replacement windows, at 170 pounds, or 235 to do a glass conversion - yet for a glass robbins it is $500US. (plus shipping for them from the respective countries...)
Richee
Postby Richee » Sun Aug 12, 2007 5:08 pm
Buy a second hand glass window top with Frame, easy swap over (apparently) :mrgreen:
I think someone here wants to get rid of his, also check out Mania they usually have some.
Richard
Mazda Tribute - its a boat
Coming - Jayco Eagle wind up camper - woo hoo
Ex cars 2007 NC LE Radiant Ebony, 1990 Eunos Neo Green LE
phaedo
Postby phaedo » Sun Aug 12, 2007 5:50 pm
Richee wrote:Buy a second hand glass window top with Frame, easy swap over (apparently) :mrgreen:
Richard
Will give Mania a call, see what they have. Although it may be time for a new roof anyway, don't think it is properly waterproof any more, got what appears to be a bit of mold maybe starting on the inside - will have to get that cleaned up. Here is a picture anyway of the window...
Richee
Postby Richee » Mon Aug 13, 2007 8:56 am
mmmm bugga
Postby bruce » Mon Aug 13, 2007 11:23 am
Some clear contact and you're done !
