re-named which cams!? tomei's from who?
irwin83r
Postby irwin83r » Fri Aug 10, 2007 8:19 pm
anyone imported tomie cam shafts for an NB8A? or can anyone recommend someone to get them through?
cheers
a.irwin
Rob E
Postby Rob E » Fri Aug 10, 2007 9:28 pm
rhdjapan.com can send them down for you 8)
irwin83r
Postby irwin83r » Fri Aug 10, 2007 11:28 pm
woo
http://www.modyourcar.com.au/advanced_search_result.php?search_in_description=1&inc_subcat=1&car_make=&categories_id=56&brand=&car_model=&car_engine=&uni=&sort=&cPath=8_56&keywords=mazda&x=0&y=0
anyone delt with these guys before?
anyone ran toda camshafts before? will they work with standard head and a shim kit?
or am i better off going the tomei's??
Rob E
Postby Rob E » Sat Aug 11, 2007 12:45 am
irwin83r wrote:woo
700 bucks per cam? :lol:
Babalouie
godfather of saké
Postby Babalouie » Sat Aug 11, 2007 12:48 am
The Tomeis are not much more than $700 for both cams :D
irwin83r
Postby irwin83r » Sat Aug 11, 2007 12:29 pm
700 for the pair from who though? and that for NA cam shafts or NB cam shafts?
the NB's have solid lifters i hear and that makes installing cams (even on the NB8As) alot more expensive.
are tomei the way to go with a standard head and motor just with a CAI and full exhaust system? or can i go a little more wild?? :D
Babalouie
godfather of saké
Postby Babalouie » Sat Aug 11, 2007 1:33 pm
irwin83r wrote:700 for the pair from who though? and that for NA cam shafts or NB cam shafts?
Ahh that's right you have an NB. I paid $750 for a pair ot Tomeis, but that was over the counter in Japan. For the NB it's a lot more expensive because you also need the lifter kit too....to be honest I am not sure if the modest power gain would be worth the expense IMHO. Different case for the NA of course.
irwin83r
Postby irwin83r » Sat Aug 11, 2007 8:40 pm
what grinds are out there for the NB8A's? is it worth while getting the wildest grind i can fit in the standard head or is that not worth while if the rest of the head is remaining standard? i will be putting in an ecu of some sort
Rob E
Postby Rob E » Sat Aug 11, 2007 11:25 pm
irwin83r wrote:what grinds are out there for the NB8A's? is it worth while getting the wildest grind i can fit in the standard head or is that not worth while if the rest of the head is remaining standard? i will be putting in an ecu of some sort
Hi mate, how far are you prepared to go?
IRTB?
irwin83r
Postby irwin83r » Sun Aug 12, 2007 1:46 am
basically i want to crack the big 1 0 0 rwkw.. but since i plan on going turbo later, on another motor i dont want to go all out on this one.. so cant say i can justify the IRTB's... cams i maybe able to reuse though
i have a short cold side CAI, 4-1 extractors, highflow cat 2.5\", into high flow rezonator and muffler 2.25\"
im basically looking at Cams and ECU then ill be done for awhile and start saving for the big things :?
so yeah the motor its self will be left standard internally other than the cam shafts. so what i want to know is will it be worth while getting some wild cams? or should i just stick to the tomei's and alike??
and if so where should i get them if i dont want to be ripped off :shock:
Babalouie
godfather of saké
Postby Babalouie » Sun Aug 12, 2007 2:05 am
I'd reckon that you wouldn't want to go much bigger (if at all) than the Tomeis.
They apparently peak slightly higher than the stock redline (the power curve is still building when you hit the limiter) so getting cams that shift the powerband any higher would be a bit of a waste. If the BP engine could rev to 8000rpm stock then yes cams that peak between 7~8k would be awesome, but sadly the BP is not such a motor :)
And I reckon with a turbo you wouldn't want really really big cams anyway.
irwin83r
Postby irwin83r » Sun Aug 12, 2007 12:00 pm
RaceSupplies wrote:Tomei claim 10ps increase using their 252/256 cams.
I am getting a price for you for everything needed.
I am also pricing the TODA cams as well as TODA cam gears which would be a worthwhile investment (as long as the tuner knows how to use them!) to dial in the cams for where you want the torque produced.
They aren't very expensive.
thanks mate.
the cam gear really needed while NA? from my understanding the tomei's are basically set at factory anyway? i was under the impression that the adjustable cam gears were really only needed for FI setups? anyone able to clear this up?
thanks again
irwin
Babalouie
godfather of saké
Postby Babalouie » Sun Aug 12, 2007 1:19 pm
thanks mate.
thanks again
irwin
The instructions for my Tomeis said that ideal timing was 110/110, which is what you get if you just re-use the stock cam gears. I got a 8rwkw gain from my Tomeis, although I am surprised by that since it doesn't feel that dramatic...
kula
Postby kula » Mon Aug 13, 2007 5:23 pm
hioctaneracing.com.au are the tomei kings in aus :)
Postby Okibi » Mon Aug 13, 2007 7:46 pm
Have you looked at the Toda Racing ones?
I think they're the only people to make adjustable cam gears for the NB8A (if required).
