Frozen rear demister?
marcusus
Postby marcusus » Tue Aug 07, 2007 11:19 pm
So I've recently noticed on cold days (less than 5 degrees or so in the morning) my rear demister seems to not work.
After driving around with the heater on for a while, it comes back to life. Admittedly, I haven't tried driving around with the heater off to see if it comes back to life irrespective.
My best guess is that there are metal contacts somewhere which have shrunken due to the cold, and that the warm air expands the metal so they contact again, thus bringing the demister back into action.
Anyone ever experienced this before?
When I have time, I'm gonna try checking the plug that sits behind the passenger seat and perhaps also the fuses for tightness. Are there any other connection points that go from the button to the demister?
Fuzzlet
Postby Fuzzlet » Tue Aug 07, 2007 11:52 pm
Maybe its so damn cold it just cant get the heat into the glass, and needs the main heater to take the initial chill off?
marcusus
Postby marcusus » Wed Aug 08, 2007 10:46 pm
Fuzzlet wrote:Maybe its so damn cold it just cant get the heat into the glass, and needs the main heater to take the initial chill off?
It's not a problem of applying the electrical heat to the glass, because the actual demister doesn't trigger the relay. The demister light doesn't turn on, and nor do I get the usual audible relay click when it works.
So no one else has come across this? I'm surprised I'm the only one... unless it's a problem specific to my car, in which case it'll mean pulling everything apart again to check connections...
Craig
Postby Craig » Wed Aug 08, 2007 10:57 pm
marcusus wrote:It's not a problem of applying the electrical heat to the glass, because the actual demister doesn't trigger the relay. The demister light doesn't turn on, and nor do I get the usual audible relay click when it works.
You may have answered your own question there, try replacing the relay perhaps? :)
marcusus
Postby marcusus » Wed Aug 08, 2007 11:06 pm
Craig wrote:You may have answered your own question there, try replacing the relay perhaps? :)
Hmmm... depends whereabouts the relays are located. Any clues? I have some doubts that a relay would sporadically fail like that. Usually that type of stuff is very discrete (and I should know, considering I work with control systems all day, albeit not in these situations) and the only thing that would cause it would be in the relay not contacting.
I just find it funny that it works once it's warmed up. Bit of a lose lose situation... if it's too cold and my rear window is frosted up and I can't defrost it, but if it's warm enough, it doesn't have any frost on it.
So this is just me then?
Craig
Postby Craig » Wed Aug 08, 2007 11:27 pm
Be under the dash with all the other ones! :lol:
What about the spade connector that goes onto the back of the hardtop...might be loose and/or the solder that holds it onto the rear window might be dodgy.
marcusus
Postby marcusus » Thu Aug 09, 2007 7:26 pm
Craig wrote:Be under the dash with all the other ones! :lol:
No hard top. This is the soft top demister. Anyway, I've already tried jiggling the connector (disconnecting it, reconnecting it, shoving it in as hard as I can etc) and it hasn't seemed to make a difference. Although it's been a bit warmer lately, so it's been working without incident.
As for the location, I suppose it must be somewhere near the fuses. I can always hear it clicking over around there, so it might be worth checking around there to see what I can find.
Alex
Postby Alex » Fri Aug 10, 2007 7:25 pm
hmm when it is working just keep pressing the button and follow your ears to the relay
marcusus
Postby marcusus » Fri Aug 10, 2007 9:25 pm
SM wrote:hmm when it is working just keep pressing the button and follow your ears to the relay
Yeah, was gonna give that a shot when I had a spare weekend. At least it's been warming up quite a lot lately so the demister's been working alright.
Craig
Postby Craig » Fri Aug 10, 2007 10:23 pm
What about a hairline crack in the metal strips running across the rear window? Grab a multimeter and test it's continuity when it's cold and then again when it's warm. Just remember to unplug the plug first to take it out of the circuit. :)
marcusus
Postby marcusus » Fri Aug 10, 2007 10:43 pm
Craig wrote:What about a hairline crack in the metal strips running across the rear window? Grab a multimeter and test it's continuity when it's cold and then again when it's warm. Just remember to unplug the plug first to take it out of the circuit. :)
Hmmm... That actually sounds like it could be a good option. The biggest problem is waking up early enough on a weekday to have time to get out there and put the multimeter on it :P
Either way, I'll keep it in mind and hopefully I'll remember to give it a shot when it's cold enough.
Craig
Postby Craig » Fri Aug 10, 2007 10:47 pm
:lol: Just sleep in all the time then until it's warmed up...problem solved! :P
marcusus
Postby marcusus » Fri Aug 10, 2007 11:26 pm
Something tells me work won't look too kindly on that type of arrangement :P
Alex
Postby Alex » Sat Aug 11, 2007 1:30 am
I don't think it would be a crack in the heating elements, my other car has that problem but the rest of them still heat up so I normally have a single line of frost in my rear window
marcusus
Postby marcusus » Sun Aug 19, 2007 5:15 pm
It could be across the return wires or something, causing all of them to fail in the cold.
Still haven't had a chance to look at it because I've been away this past week. Maybe the coming weekend...
Users browsing this forum: No registered users and 68 guests
