Oil pan / sump removal
silverback2002
Postby silverback2002 » Thu Aug 09, 2007 6:51 pm
Does anyone know how to remove the sump on a NA 1.8 mx5
I have all the bolts off and it has dropped a couple mm all round. I have the Gearbox out and the engine will be lifted a couple of inches with an engine crane.
It seems to be holding on something thought and im not sure what.
It wiggles but wont drop and rest on the sub frame.
Any help would be great.
Thanks
Dan
Sean
Postby Sean » Thu Aug 09, 2007 7:23 pm
They can be tricky buggers to get out/off.
The windage tray is connected to the sump and is also glued to the bottom of the block (I know from experience it is in 1.6s and early 1.8s assuming yours is teh same).
SO the sump will drop but you still need to loosen the thin metal windage tray from teh block before the sump will fully come off.
Uncle Arthur
Dodgy Award Benefactor
Postby Uncle Arthur » Thu Aug 09, 2007 7:30 pm
Sean wrote:They can be tricky buggers to get out/off.
What he said.
silverback2002
oil pan
Postby silverback2002 » Thu Aug 09, 2007 10:49 pm
Thanks,
When I shine a torch in there I can see the tray its seperated from the block because I can see the crank. The tray is lower on the sump side.
Maybe once I lift the motor to get more clearance it will be easier.
So I should be able to just pull it off.
I wont be breaking anything with a firm yank.
Uncle Arthur
Postby Uncle Arthur » Thu Aug 09, 2007 11:26 pm
The windage tray is actually attached to the engine by the oil pickup. The tray bolts to the pickup pipe, which bolts to the block.
You have to remove the windage tray from the sump to then remove the tray separately.
Separate the two with a razor blade - gently.
It is easier when you have better access to the motor.
silverback2002
Postby silverback2002 » Thu Aug 09, 2007 11:43 pm
Thanks,
Worked it out. Its well stuck to the sump, once seperated the sump should then just drop out correct. I can then remove the pickup hose and remove the tray to clean it all up.
I have 3 bond from mazda is that a good product to use to seal it all up again.
Uncle Arthur
Re: Oil pan / sump removal
Postby Uncle Arthur » Fri Aug 10, 2007 9:18 am
silverback2002 wrote:Thanks,
I used copper gasket maker which is what's recommended in the service manual.
mxfive95
Postby mxfive95 » Sun Jan 29, 2012 2:20 pm
Lol, here I am with the same problem :) good thing I did a search :)
The bumper sticker on my porsche
"My other car is an mx5"
Users browsing this forum: No registered users and 49 guests
