Which prop shaft?
Moderators: timk, Stu, zombie, -alex
Which prop shaft?
I understand there are two different sized prop shafts for early MX5s.
My diff flange's adjacent bolt centres are 70mm apart.
The diff is from a 1.8, and is a Torsen if that helps.
Is this the \"big\" or \"small\" prop shaft?
& while you're still reading, what are they worth 2nd hand?
Thanks - Gavin.
Thanks - Gavin.
Cheers - Gavin Eakins,
Emerald, Victoria.
Emerald, Victoria.
Gavin, as mentioned by JBT you need a 1.8l prop drive shaft and the two drives shafts, assuming you are trying to fit a 1.8l torsen diff to a 1.6l MX-5. The prop shaft and drive shafts from any MX-5 from late 1993 to 2004 should fit.
On the pricing all I can say is that a 1.8l torens diff, with prop shaft and two drive shafts will usually set you back between $1500 and $1800.
J
J
Juffa wrote:Gavin, as mentioned by JBT you need a 1.8l prop drive shaft and the two drives shafts, assuming you are trying to fit a 1.8l torsen diff to a 1.6l MX-5. The prop shaft and drive shafts from any MX-5 from late 1993 to 2004 should fit.
J
Thanks, but it's only the prop shaft itself that I need.
I have the complete 1.8 diff, including drive shafts, and need the bit to put between it and the gearbox.
It's not actually for a MX5, but for a clubman I'm building.
So, the message is "get a 1.8 prop shaft" - thanks!
Gavin.
Emerald, Victoria.
Emerald, Victoria.
- SuperMazdaKart
- adamjp
A Lotus 7 Clubman is usually a kit car.
Same appearance as the Caterham, PRB and Westfield clubbies.
When built yourself to the 'plan' they are often called Locosts.
Look a fair bit like this, but usually don't go as well.
http://www.westfield-sportscars.co.uk/megabusa.html
Adam
- Boyracer
- MX-5 Encyclopedia
Fatty wrote:ooh this sounds interesting gavin. i'd sure we'd all love to see some pics of this clubman !
I could show you photos of it, but you'd only see a pile of tubes sitting on the bench. It'll be something like this when done:
Mine will have a MX5 rear end + box, Duratech 2l up front. About 600kg all up.
Emerald, Victoria.
Emerald, Victoria.
- bigdog
- King of the kennel
bigdog wrote:Nice colour scheme Gavin
Mines a little older though... built 1965
G'Day Bigdog,
It's interesting comparing the two for proportions. The CMC kit that Tanner used (my photo) has such a higher scuttle / bonnet, where yours is hardly there at all! Your car also looks much narrower. I like the line down the scuttle/bonnet of yours.
To be honest, I chose that photo as just an example - for me, I don't want the aluminium / paint mix, and will go for a block colour. A hot rod mate is trying to convince me to get rid of my planned alloys / licorice strip tyres & install whitewalls + a flame job! At least it'd stand out from most clubmans, where they follow much the same form.
Gavin.
Emerald, Victoria.
Emerald, Victoria.
- bigdog
Mine is loosely modelled on a lotus chassis and width is dictated by the diff (BMC A series) on these cars. Engine is 1098cc Ford Anglia, as is gear box. Car was designed and built by Paul Trevethan in melbourne. I found and restored it in 1985 to run in historics. One thing you need on yours is an aero screen - I ran without one at Eastern Creek once and nearly tore my head off when the wind got under my helmet on the straight...
bigdog wrote:Mine is loosely modelled on a lotus chassis and width is dictated by the diff (BMC A series) on these cars. Engine is 1098cc Ford Anglia, as is gear box. Car was designed and built by Paul Trevethan in melbourne. I found and restored it in 1985 to run in historics. One thing you need on yours is an aero screen - I ran without one at Eastern Creek once and nearly tore my head off when the wind got under my helmet on the straight...
I understand. As crazy as it might seem, I'm aiming for a "comfy" (!) road car, so I'll be putting a full windscreen + heater + wipers etc. on mine. I get the "tore my head off" bit though - I'm a bike rider more than a car driver.
Your machine sounds really interesting. I bet you have to keep working at it to keep up a reasonable speed.
Gavin.
Emerald, Victoria.
Emerald, Victoria.
- bigdog
Redline is 10000rpm, and it spends all day at 8000! 95 engine bhp @ 8000 is pretty cool for a little tiny beasty with no computers or trickery, just good old fashioed points and Weber carbs It has the best exhaust note this side of an F1 car too...
here's my favourite piece of automotive art... by the one and only Brian Caldersmith:
Return to “Engine swaps, Exocet, Locost & MX-5 kit cars”
