Which prop shaft?
Discussion regarding putting a non MX-5 engine in your MX-5, Exocet, Locost, FM Westfield and other MX-5 based kit cars.
Moderators: timk, Stu, zombie, -alex
gavin_eakins
Which prop shaft?
Postby gavin_eakins » Wed Aug 08, 2007 2:34 pm
I understand there are two different sized prop shafts for early MX5s.
My diff flange's adjacent bolt centres are 70mm apart.
The diff is from a 1.8, and is a Torsen if that helps.
Is this the \"big\" or \"small\" prop shaft?
& while you're still reading, what are they worth 2nd hand?
Thanks - Gavin.
Cheers - Gavin Eakins,
Emerald, Victoria.
JBT
Postby JBT » Wed Aug 08, 2007 2:43 pm
You'll need a 1.8 prop shaft. You'll also need 1.8 drive shafts. No idea on cost.
Juffa
Postby Juffa » Wed Aug 08, 2007 4:02 pm
Gavin, as mentioned by JBT you need a 1.8l prop drive shaft and the two drives shafts, assuming you are trying to fit a 1.8l torsen diff to a 1.6l MX-5. The prop shaft and drive shafts from any MX-5 from late 1993 to 2004 should fit.
On the pricing all I can say is that a 1.8l torens diff, with prop shaft and two drive shafts will usually set you back between $1500 and $1800.
J
gavin_eakins
Postby gavin_eakins » Wed Aug 08, 2007 6:57 pm
Juffa wrote:Gavin, as mentioned by JBT you need a 1.8l prop drive shaft and the two drives shafts, assuming you are trying to fit a 1.8l torsen diff to a 1.6l MX-5. The prop shaft and drive shafts from any MX-5 from late 1993 to 2004 should fit.
J
Thanks, but it's only the prop shaft itself that I need.
I have the complete 1.8 diff, including drive shafts, and need the bit to put between it and the gearbox.
It's not actually for a MX5, but for a clubman I'm building.
So, the message is "get a 1.8 prop shaft" - thanks!
Gavin.
Emerald, Victoria.
Fatty
Postby Fatty » Wed Aug 08, 2007 7:09 pm
ooh this sounds interesting gavin. i'd sure we'd all love to see some pics of this clubman !
SuperMazdaKart
Postby SuperMazdaKart » Wed Aug 08, 2007 7:38 pm
sounds good, this like a kit car such as the Super 7s?
adamjp
Postby adamjp » Wed Aug 08, 2007 9:13 pm
A Lotus 7 Clubman is usually a kit car.
Same appearance as the Caterham, PRB and Westfield clubbies.
When built yourself to the 'plan' they are often called Locosts.
Look a fair bit like this, but usually don't go as well.
http://www.westfield-sportscars.co.uk/megabusa.html
Adam
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Thu Aug 09, 2007 9:09 am
It's more long and short rather than big and small,the 1.8 shaft is shorter than the 1.6.
gavin_eakins
Postby gavin_eakins » Thu Aug 09, 2007 10:20 am
Fatty wrote:ooh this sounds interesting gavin. i'd sure we'd all love to see some pics of this clubman !
I could show you photos of it, but you'd only see a pile of tubes sitting on the bench. It'll be something like this when done:
Mine will have a MX5 rear end + box, Duratech 2l up front. About 600kg all up.
Emerald, Victoria.
bigdog
King of the kennel
Postby bigdog » Thu Aug 09, 2007 11:21 am
Nice colour scheme Gavin 8)
Mines a little older though... built 1965 :D
gavin_eakins
Postby gavin_eakins » Thu Aug 09, 2007 2:22 pm
bigdog wrote:Nice colour scheme Gavin 8)
G'Day Bigdog,
It's interesting comparing the two for proportions. The CMC kit that Tanner used (my photo) has such a higher scuttle / bonnet, where yours is hardly there at all! Your car also looks much narrower. I like the line down the scuttle/bonnet of yours.
To be honest, I chose that photo as just an example - for me, I don't want the aluminium / paint mix, and will go for a block colour. A hot rod mate is trying to convince me to get rid of my planned alloys / licorice strip tyres & install whitewalls + a flame job! At least it'd stand out from most clubmans, where they follow much the same form.
Gavin.
Emerald, Victoria.
bigdog
King of the kennel
Postby bigdog » Thu Aug 09, 2007 3:15 pm
Mine is loosely modelled on a lotus chassis and width is dictated by the diff (BMC A series) on these cars. Engine is 1098cc Ford Anglia, as is gear box. Car was designed and built by Paul Trevethan in melbourne. I found and restored it in 1985 to run in historics. One thing you need on yours is an aero screen - I ran without one at Eastern Creek once and nearly tore my head off when the wind got under my helmet on the straight... :roll: :lol:
gavin_eakins
Postby gavin_eakins » Thu Aug 09, 2007 6:34 pm
bigdog wrote:Mine is loosely modelled on a lotus chassis and width is dictated by the diff (BMC A series) on these cars. Engine is 1098cc Ford Anglia, as is gear box. Car was designed and built by Paul Trevethan in melbourne. I found and restored it in 1985 to run in historics. One thing you need on yours is an aero screen - I ran without one at Eastern Creek once and nearly tore my head off when the wind got under my helmet on the straight... :roll: :lol:
I understand. As crazy as it might seem, I'm aiming for a "comfy" (!) road car, so I'll be putting a full windscreen + heater + wipers etc. on mine. I get the "tore my head off" bit though - I'm a bike rider more than a car driver.
Your machine sounds really interesting. I bet you have to keep working at it to keep up a reasonable speed.
Gavin.
Emerald, Victoria.
bigdog
King of the kennel
Postby bigdog » Thu Aug 09, 2007 8:22 pm
Redline is 10000rpm, and it spends all day at 8000! 95 engine bhp @ 8000 is pretty cool for a little tiny beasty with no computers or trickery, just good old fashioed points and Weber carbs 8) It has the best exhaust note this side of an F1 car too... :P
here's my favourite piece of automotive art... by the one and only Brian Caldersmith:
Return to “Engine swaps, Exocet, Locost & MX-5 kit cars”
