What are the major costs of going turbo?
Bevan
Postby Bevan » Thu Aug 02, 2007 12:40 am
Just wondering the major costs of going turbo are? My mate (Pete) bought an SE and driving his car has given me the turbo bug again. Two things that I realise are:
1) It's just another one of my phases, and
2) It's not going to happen
BUT hypothetically, what are the major costs?
Obviously, there's the big hardware:
Turbo - $400
Manifold - $350 (with dump pipe)
Dump pipe - $350 (with manifold)
Intercooler - $150
Intercooler piping - ?
You've also got:
Water/Oil lines - ?
BOV - ?
Boost controller - $20 (DIY)
Boost gauge - $50
O2 clamp - ?
Couplers - ?
Clamps - ?
Misc hoses and fittings (return line, vacuum etc) - ?
Heat shielding - ?
Please add any parts and pricing and I will edit this original post.
Thanks!
Bevan :)
Craig
Postby Craig » Thu Aug 02, 2007 12:42 am
Just buy an SE you boofhead! :P
Bevan
Postby Bevan » Thu Aug 02, 2007 12:49 am
Craig wrote:Just buy an SE you boofhead! :P
Bevan wrote:Two things that I realise are:
:mrgreen:
CT
Postby CT » Thu Aug 02, 2007 7:46 am
Here's a couple...
- ECU, installation and tuning.
- Decent radiator
- Oil cooler
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Thu Aug 02, 2007 8:08 am
And don't forget insurance and registration hassles...
Just buy a SE you boofhead... :lol: :lol:
Richee
Postby Richee » Thu Aug 02, 2007 8:18 am
Your mates car goes faster than yours so go on, buy a SE ya boofhead :D :D
Mazda Tribute - its a boat
Coming - Jayco Eagle wind up camper - woo hoo
Ex cars 2007 NC LE Radiant Ebony, 1990 Eunos Neo Green LE
bigdog
King of the kennel
Postby bigdog » Thu Aug 02, 2007 9:52 am
You know what I reckon Beverly... buy an SP you boofhead! :P :P
Boags
Postby Boags » Thu Aug 02, 2007 10:32 am
bigdog wrote:You know what I reckon Beverly... buy an SP you boofhead! :P :P
Werd.
Injectors - $200 (cleaned)
Turbo - $400
Manifold and dump pipe - $800
Intercooler - $150
Intercooler piping - 400
You've also got:
Water/Oil lines - $150
BOV - $20 (stock rx7 one sounds cool and works up to 12PSI)
Boost gauge - $50
O2 clamp - Forget this, get an ECU and tuning - $1500
Couplers - all part of your $400 for piping
Clamps - ditto
Misc hoses and fittings (return line, vacuum etc) - $150 (there is a lot of misc stuff)
Heat shielding - I made mine for about $25 I think.
Radiator - $400
Oil cooler - $150
I'd buy an SP, or Mossy's car. 8)
Boags
sprx3
Postby sprx3 » Thu Aug 02, 2007 10:48 am
Dont listen to these boofheads call avo and get the non electrics kit for 3200 :) you have an emanage so unless you want to upgrade things like exhaust that the price
want to join the mazda car club of australia?, for more info please p.m me
Boags
Postby Boags » Thu Aug 02, 2007 10:50 am
Don't forget the hoops that Fuzzlet is jumping through to pass the emissions tests... Lots of $$$ there - unless you live in QLD. :lol: :mrgreen:
Boags
Craig
Postby Craig » Thu Aug 02, 2007 10:55 am
Right...it's official...Bevan's a boofhead! :lol:
Uncle Arthur
Dodgy Award Benefactor
Postby Uncle Arthur » Thu Aug 02, 2007 10:57 am
And add in between $500-$1500 for an exhaust, depending on what you want...
Plus diff (LSD) $1000
Brakes - at the very least have them checked out - potentially upgrade the rotors
How old is the motor? Done water pump and timing belt change yet?
Seals?
You want to budget up to $10K in total. While the turbo kit might only be $3-3.5K, there's a lot of other stuff that goes with it, and you haven't even addedd in the cost of getting it tuned - which varies on what system you choose........ and how much you can do yourself.
Garry
Postby Garry » Thu Aug 02, 2007 11:47 am
Just spend $10K and buy an SE, it's much easier.
Fuzzlet
Postby Fuzzlet » Thu Aug 02, 2007 12:50 pm
Boags'MX5 wrote:Don't forget the hoops that Fuzzlet is jumping through to pass the emissions tests... Lots of $$$ there - unless you live in QLD. :lol: :mrgreen:
Boags
Yep....I've failed 4 emissions tests so I've given up, returning the clubman to stock and selling it
Garry wrote:Just spend $10K and buy an SE, it's much easier.
Exactly what I've done - all the goodies from the white car will be put into the SE
Seriously Bevan, the RTA emissions test is so bloody hard to pass. You would be much better off upgrading to an SE, not just because everything is already done for you, but if you get checked for defects, you will be covered by the factory engineering, adding a bit more boost wont involve getting a major retune....that and the fact that u can spend 6k turboing your car, and it'll still only be work 24k....with an SE, it'll cost a little more than turboing your current car, but it'll be worth that much, the insurance on a modified SE is less than a turbo'd older model (the insurance on my SE is less than my clubman with a turbo....SE is 3 years old, clubman is 13....go figure)
ampz
Vehicle: NA6 - Turbo
Postby ampz » Thu Aug 02, 2007 1:53 pm
Just getting in line to call you a Boofhead :P
But if you want I can give you a hand to whack a hairdryer on :P
I can help you tune it with the laptop as long as you promise no to drive too fast :shock: :mrgreen:
***Back in my box***
Huh?
