Replacing NB double DIN head unit
Fuzzlet
Postby Fuzzlet » Mon Jul 30, 2007 1:04 pm
I removed the original headunit today, but am baffled as to how one is supposed to mount a replacement in there....What have others done?
Garry
Postby Garry » Mon Jul 30, 2007 1:06 pm
Have a look at an NB8A. They came with a single DIN headunit fitted into the same console facia. You should be able to get all the bracketry you need from that.
Bevan
Postby Bevan » Mon Jul 30, 2007 1:31 pm
Garry wrote:Have a look at an NB8A. They came with a single DIN headunit fitted into the same console facia. You should be able to get all the bracketry you need from that.
:shock: So simple and makes so much sense! Didn't even think of that and I used to actually own an NB8A. :oops:
With my last head unit, I just had it sitting in there, relying on the DIN pocket to hold it up. I wan't very happy with that.
On my current head unit, I've done a MUCH better solution
- You'll see 2 holes on the plastic frame right where you would imagine the 1 DIN to end.
- I got two blanking plates from the back of a computer (the bits that you take off to add a PCI card) and taped them together at the right length. If you could find a long, very thin strip of metal that will go the width of the face, it would be better.
- In the 2 holes in the frame, I put in two long, thin bolts. Each bolt has two nuts on it. Use 1 nut to screw the bolt in tightly. The head of the bolt should be facing the cockpit and the body goes toward the firewall.
- Place your metal strip on the top of the two bolts.
- Use the other nuts to secure the metal strip in place.
That's how I made my McGyver-like frame anyway... :oops: :) 8)
Fuzzlet
Postby Fuzzlet » Mon Jul 30, 2007 2:04 pm
Yeah I've got to go to mania to check up on the clubman, so I might see if they have any bits off a wrecked car
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Sat Aug 04, 2007 9:59 am
The single Din radio has 2 little brackets that screw on to the side of the radio and they just clip in to the dash,you should be able to use these clips on an aftermarket head unit.
I have a Jap spec. Bose CD head unit and the plastic pocket to sell if someone is interested.
Fuzzlet
Postby Fuzzlet » Mon Aug 06, 2007 12:04 am
Boyracer wrote:The single Din radio has 2 little brackets that screw on to the side of the radio and they just clip in to the dash,you should be able to use these clips on an aftermarket head unit.
The double din (non bose) stereo has these same clips, but they can't really be used in the new headunit, as its not quite double din...I may have to make up an adapter of some sort...
Fuzzlet
Postby Fuzzlet » Tue Aug 07, 2007 10:52 pm
Well said adapter has been made up...using the mounting cage off an NA...having said that, i've used 2 really small parts off it, but they work a treat. They hold the HU at the right height, plus secure it in place. Only problem, is the new HU isnt quite double din, so doesnt fill the original hole fully...I'm gonna have to make up something to fill in the gaps...
jules
Guitar Hero
Postby jules » Wed Aug 08, 2007 2:17 pm
Perhaps use the later NA fascia with the correct width?
Jules
Fuzzlet
Postby Fuzzlet » Wed Aug 08, 2007 3:21 pm
jules wrote:Perhaps use the later NA fascia with the correct width?
Jules
Slight problem - Ive been fitting this to an SE :P
The headunit is normal width, but the pocket size is 5mm wider each side...the headunit had a 10mm gap at the bottom when it was in the NA, but now has 10mm on both the top and bottom...
jules
Guitar Hero
Postby jules » Wed Aug 08, 2007 3:24 pm
Blonde moment. Where's Bevan?
Jules
Bevan
Postby Bevan » Wed Aug 08, 2007 3:41 pm
jules wrote:Blonde moment. Where's Bevan?
Jules
WAKE UP JULES!!!!!! :lol:
Ah, that's better. Haven't done that in a while! :mrgreen:
Robbo107672
Postby Robbo107672 » Tue Aug 14, 2007 8:00 pm
Hi, sorry to slightly go OT on this but can anyone tell me if the standard SE head unit has any inputs on the back ? ie, RCA, etc to use for Ipod input ??
Tks
Fuzzlet
Postby Fuzzlet » Tue Aug 14, 2007 9:29 pm
Nope it doesnt, however there is a plugin available so u can plug your ipod or mp3 player etc into it.....you'd be much better changing stereos...thats what i did, and its heaps better
jules
Guitar Hero
Postby jules » Wed Aug 15, 2007 2:08 pm
Jules
:lol: :lol: :lol:
Postby sliq » Mon Sep 10, 2007 4:10 pm
do you guys know anywhere in sydney that sell mounting brackets? i've tried my local repco and autobarn and mazford, no stock ]=
