Depending on which bushes are worn you can expect the following symptoms.
Loose feeling and wondering steering
Handling goes off somewhat and the car feels a little sloppy in the corners and can wander around a bit when conrnering
Squeeks and rattles that you haven't heard before
+ many other little things.
A 100,000 k's is a good life for a standard bushing.
What are the signs of worn bushes?
- Benny
- bigdog
- King of the kennel
- ducktape69
ducktape69 wrote:how much does it usually cost to change bushes?
ive been hearing some soft creaks coming from the rear when i enter/exit driveways at slow speed lately....
Around $600 for the super pro bushes + installation.
J
- Caffeine
Re: What are the signs of worn bushes?
Roodosutaa wrote:The car's edging 100kkm and lately I've noticed a little bit of wandering about on bumpy roads, that's despite a firm grip on the wheel. I've always kept the alignment in check, so can it be the bushes?
Try adjusting the steering lash, tightened up my wandering steering nicely...
- StanTheMan
Juffa wrote:ducktape69 wrote:how much does it usually cost to change bushes?
J
LOL
err you can get them as low as $450 +postage & fitting.
http://www.nahux.com/NPOWER/vehicle_pro ... d=2&cid=49
Steering rack bushes RaceSupplies refers to are not part of above kit from N*Power. so that would be an exrta.
They were not part of the kit I purchase in the group buy earlier this year either.
NB's have a different rear sway bar end link to the NA's so if you order one for an NB you only require 1 pack of sway bar bushes.
Just don't ask me how I know.
IMHO, don't bother with the offset bushes they are really not required for a road car.
You could try to just do the sways & link ends first. I installed those first.....a few weeks before the rest. Those made a huge difference for me.
I dare say its prolly enough in your case, if Caffeins suggestion doesn't work.
Big Dawg wrote:First sign of worn bushes is Stan the Man organising a Dodgy Day in my experience
