running too rich?
running too rich?
How can you tell and how easy is it to adjust?
I'm just suspecting cos there's a really strong petrol smell, esp when the engine's just started and the economy seems poorer than usual.
Thx
Thx
- PUR157
- Sean
Re: running too rich?
atomic wrote:How can you tell and how easy is it to adjust?
Thx
It's not easily or readily adjustable. Although if it is running rich something will be casing it to be that way, get that fixed and your problem is solved!
- StanTheMan
but one way to do it....is Get your ECU Polarised.
or muck around with the spring in your AFM if your car is a NA6.....not possible on anything later
But both should be aproached with care & common sense. And like Sean suggested.....fix everything else first before you start mucking around with those bits.
- StanTheMan
- StanTheMan
what sort of economy are you getting
what type of driving are you doing.
eg short trip, long trips, city driving......so on.
first thing I get is when i'm reversing out.....is a whif of petrol. But its real cold atm & my trips are few & very short. Fuel econ is crap......but thats expected
- Boags
StanTheMan wrote:lets start with the type of Car you have
Actually you've seen my car - yellow NA6, black rims....
StanTheMan wrote:what sort of economy are you getting
just regular driving, 20+ min trips around syd suburbs, usually not too much traffic
Maybe it's normal then? No black marks around the exhaust/rear bumper but I definitely get a strong whiff of petrol.
I've just been noticing that I'm getting close to 10L/100km whereas before I used to get around 8L/100km...
Sounds very O2 sensor-ish to me. If it's 4-wire now just replace it, if it's a single wire then upgrade to 4-wire and it'll be much better from cold.
http://www.aus-cartalk.com/viewtopic.php?t=25609
http://mymiata.paladinmicro.com/Miata4-WireO2.htm
http://www.aus-cartalk.com/viewtopic.php?t=25688
... and maybe another 10 or 20 O2 sensor threads I have not seen as well.
- JBT
atomic wrote:......there's a really strong petrol smell, esp when the engine's just started and the economy seems poorer than usual.
You don't necessarily smell fuel when running rich. A "really strong petrol smell" is indicative of a leak.
What does the exhaust look like? Is it blowing plumes of black smoke?
- Vehicle: ND - 2
