Wheel hub bolt removal/installation
Insurgence
Postby Insurgence » Sun Jul 08, 2007 8:05 pm
Has anyone had the pleasure of replacing wheel hub bolts?
e.g.
http://www.stealth316.com/2-wheelbolt.htm
I have the workshop manual and it says to use a press. Can I use a vice? or do I have to take it to a workshop to get it done?
NB8A
Russellb
RIP Nov 2014
Postby Russellb » Sun Jul 08, 2007 9:50 pm
Smack the old one out with a Hammer
place the new one in and use a spacer under the wheel nut and tighten
it up.This will pull the stud into place.
My ClubmanRebuild
MX5 SE Rally car is HERE :)
Insurgence
Postby Insurgence » Sun Jul 08, 2007 11:08 pm
Thank you very much :D
NB8A
Insurgence
Postby Insurgence » Mon Jul 09, 2007 7:12 pm
<forum future reference>Wheel hub bolts Approx $7 from MAZDA. Wheel nuts approx $6</forum future reference>
NB8A
Boost
Postby Boost » Mon Jul 16, 2007 2:26 pm
On the of studs. Is there suppose to be some free play between the studs and the rotor? Cause i notice on my NB when I had the wheels off, I could move the studs from side to side approx. 1mm. The holes on the rotorsseems to be a tad. bit bigger than the studs them selves. Is this normal.
none as yet - looking for a white NA8
Insurgence
Postby Insurgence » Mon Jul 16, 2007 9:23 pm
that doesnt sound right.
the studs themselves are held FIRMLY in place in the wheel hub, and have to be hammered out with a sledge hammer.
they are not supposed to move at all.
the brake rotor itself fits \"over\" the wheel hub (ie. the wheel studs are not attached to the rotor itself.
that being said you should not be able to move the studs from side to side AT ALL.
get it checked out before your wheel falls off :(
NB8A
Users browsing this forum: No registered users and 169 guests
