Looking for a good wheel repairer in the sydney area. Have some wheels with major gutter rash that I would like fixed up.
Anybody know of one? I heard there is a good one in Seven Hills but am yet to find out the name of the business or where it is.
Wheel repairer in Sydney. Help?
- JSE
- godfather of saké
- bigdog
- King of the kennel
- Fuzzlet
Babalouie wrote:I've just dealt with a place called Wheel Repair Centre in Thornleigh. 9980 1125. Very good to deal with.
I bit of a thread mine here, but I've just dropped 2 wheels off to these guys for repair:
1 nasty pothole in arcadia long enough to swallow the rim, caused this x2. It was a bad enough hit, that I lost the air out of both left tyres, and the rims have been buckled and knocked out of alignment...ie when they spun them up to check out the damage, they dont spin properly....gonna cost the better part of $200 per rim, plus a new tyre for the front...it had a chunk taken out of it....thank god I wasnt in the MX5 though....I would of destroyed my front suspension
- Garry
- Fuzzlet
Garry wrote:Can they repair that?!I might get my stock rim repaired. It was no where near as bad as that.
Yes, but its gonna cost about 200 per wheel for repairs...Its still better than the $500ish per wheel for a full replacement....bloody rays forged rims...
- adamjp
Most good wheel repairers can fix a knock like that. The wheel is not round anymore, so it is a 'simple' matter of making it round again.
What most cannot fix is when the wheel is buckled across the rotating axis, ie. one spoke is further in/out than the others, like when you slide sideways into a gutter with the wheel not rotating. Apparently this is an almost unfixable issue.
It is easy enough to spot, place the wheel on something that allows it to spin, and spin it. Look from above so that you are looking down on the area normally covered by the tyre. Any wobble will show up as plain as day.
I found this out the hard way with a set of Enkeis. The stuffed one wobbled so much in one spot it kinda made me motion sick.
Adam
