Fitting a B6T from a 323/TX3-->1990 MX5 (56k beware)
PSI-JET
Postby PSI-JET » Wed Jun 27, 2007 10:10 pm
Yeah but for my own safety I think I'll go something a little better than stock.
dab
Postby dab » Sun Jul 01, 2007 7:11 pm
If you are still unsure of the CAS you could always make a pickup for the cranks instead of using the cam for timing. This gives a more accurate timing reading as it does away with any slop/movement in the camgears/timming belt.
PSI-JET
Postby PSI-JET » Wed Jul 04, 2007 11:02 pm
Now that I own an MX5 it's a bit easier to see whats needed. I know there's going to be a lot of muckin about but there's more room than I had anticipated and I can now see what changes need to be made.
On a seperate note I can't understand why you can buy equal length aftermarket turbo manifolds for BP but you can only get sh!tty log style manifolds for B6. Looks like I'll be making a custom :) (which is what I expected anyway).
Motor is all paid for and arrives tomorrow, let the games begin :P
Sean
Postby Sean » Thu Jul 05, 2007 7:10 pm
I had a custom equal length one for B6 for sale on here not too long ago!
PSI-JET
Postby PSI-JET » Thu Jul 05, 2007 7:38 pm
Spewin! It would've at least got me by until I made exactly what I want.
On a happier not my engine builder kindly dropped my engine off to me this afternoon. There's still plenty of work to do starting with converting the front of the engine to adapt to the MX5 but at least my motor is home :D
here are some very \"happy\" snaps :P
Sean
Postby Sean » Thu Jul 05, 2007 8:00 pm
PSI-JET wrote:Spewin! It would've at least got me by until I made exactly what I want.
I may be able to source another one that is exactly thesame construction, but they aren't cheap, custom made etc.
PSI-JET
Postby PSI-JET » Thu Jul 05, 2007 8:03 pm
Sounds good.
I have plenty of contacts to get one made, I'd only have to pay for materials. It's still time consuming though and a hold up I don't need for now if I can source a ready made one.
