hey there,
i'm just trying to find out if there is much of a difference between the king springs and whiteline springs. i know that some ppl have said the king spring is quite firm and there is no real comprimise for comfort. haven't been able to find much on the whiteline springs. Has anyone tryed both or have experience with either?? thanks
Ant
compare king Vs whiteline
- MxJadeMonkey
Yeah have tried both of them and ended up with the kings
while being slightly firmer i found the car responded well with them
also the whiteline springs came down about 5mm more than the king to around 35mm, a little too low i think.
plus kings have lifetime warranty (agaist free height sag of more than 10mm)
hope that helps!
hope that helps!
1991 NA6 Velocity Blue (Ford Colour)
Kings aren't very good. I have a set in my 93 all they are is hard they have very bad response this makes dampening them difficult I wouldn't even consider buying a set of them without Koni shocks. In retrospect I would save a little longer and buy a set of coilovers. Do the job properly, you will see a set of Koni/Kings turn up on this site every other month with always the same reason coilover upgrade.
Mick93 wrote:Kings aren't very good. I have a set in my 93 all they are is hard they have very bad response this makes dampening them difficult I wouldn't even consider buying a set of them without Koni shocks. In retrospect I would save a little longer and buy a set of coilovers. Do the job properly, you will see a set of Koni/Kings turn up on this site every other month with always the same reason coilover upgrade.
I have to agree. Kings are best matched with Koni's or other respectable damper adjustable shocks. I cannot imagine Kings with stock shocks, cos with my current King/Koni combo it's already a tad harsh on Melbourne roads.
From what I've heard, Whiteline's are more compromising that Kings as they are developed and built in Australia. This is from my two mates that have Whiteline/Koni combo's in their S13 and S15 Sils.
- MxJadeMonkey
- Ajay
- MxJadeMonkey
- deez
Users browsing this forum: No registered users and 185 guests
