At what point should I need a baffled sump?
brenno
Postby brenno » Thu Jun 14, 2007 11:01 am
Hi all,
I'm wondering who out there uses a sump with more baffling than standard, and at what point you thought it was necessary?
It's my understanding that as the MX5 was produced, they introduced more baffles as time went on. Is that correct?
Would you advise on an oil cooler before sump baffles, or vice versa.
I'm just trying to avoid a repeat of my last trackday. Engine go boom :lol:
White NA8
Matty
Postby Matty » Thu Jun 14, 2007 4:55 pm
Having torn down a 1.6, I'd say there's plenty of baffling unless you're pulling severe G's on slicks. There's a horizontal baffle plate, and drainage ribs cast into the sump also.
You could add in a crank scraper, but that would be about it.
A relatively standard MX shouldn't overheat or lose oil pressure (assuming proper oil level) on the track, so I'd go searching for the problem before adding extra bandaids.
lowmiata
Re: At what point should I need a baffled sump?
Postby lowmiata » Thu Jun 14, 2007 6:16 pm
brenno wrote:I'm wondering at what point you thought it was necessary?
If you ever drive upsidedown?
or have you been racing against nascars?
where would you put extra baffles anyway? there aint alot of room!
or you could get the later model baffles (i didn't know there was a change but if there is maybe see when they changed and get the part no.s for the newer one)
add in an oil cooler so you are holding more oil?
would help to have extra oil flowing through the system.
are you definatly sure it was oil starvation that caused the malfunction?
it didn't get to thin under the heat?
EVI15 1998 to 2008
CT
Postby CT » Thu Jun 14, 2007 10:28 pm
90% of the MX5 race cars use stock sumps.......oil pumps on the other hand, might be a different story. 8)
brenno
Postby brenno » Fri Jun 15, 2007 9:05 am
Matty wrote:A relatively standard MX shouldn't overheat or lose oil pressure (assuming proper oil level) on the track, so I'd go searching for the problem before adding extra bandaids.
That's good to know, thanks.
White NA8
brenno
Postby brenno » Fri Jun 15, 2007 9:11 am
lowmiata wrote:are you definatly sure it was oil starvation that caused the malfunction?
Good point, I'm just assuming it was oil starvation. There was plenty of oil before the 10-15 lap session I was doing on the track. Towards the end of the session I heard the noise so pulled off and checked the level - it was just below minimum. I knew my valve stem seals were bad, but I would have thought that amount of oil usage would really make itself known with heaps of smoke.
Anyway, lesson learnt. I'll investigate an oil cooler next time I head out for longer sessions.
White NA8
Garry
Postby Garry » Fri Jun 15, 2007 9:27 am
I was reading on miatanet about a problem that's starting to appear with the 96/97 oil pumps. Is your car a late model NA?
brenno
Postby brenno » Fri Jun 15, 2007 9:30 am
Yep - 97 model.
What was the problem? Any more details?
Ta :)
White NA8
Garry
Postby Garry » Fri Jun 15, 2007 9:44 am
Sorry, dont remember exactly but basically the oil pressure drops and kills the big end.
Have a look on the miatanet forum.
Garry
Postby Garry » Fri Jun 15, 2007 11:08 am
Opps, I read about it on the Miata Email list. Sorry for the confusion. Mazda must have changed some materials or manufacturing tolerances in the 96/97 oil pumps because this seems to be the only model effected.
brenno
Postby brenno » Fri Jun 15, 2007 3:34 pm
Ta for the info. I'll check it out on the big forum.
White NA8
