Boags'MX5 wrote:Sean wrote:Hmm, AVO kit can easily be fitted drive in drive out in one saturday (including tapping the sump for oil return on the car).
Car was finished in time to take it out driving before dinner...
It can be done in one day if you know what you are doing and you have absolutely everything you need.
When you say drive in drive out, do you mean that you took it to them to install?
Boags
I mean drive in drive out at my mates shed.
2 people working on the car (me and the shed owning mate).
No air operated tools (other than the two of us
Only use of electric tool was a grinder to grind down a 14mm ring spanner to make the manifold easier to put on.
The day included some downtime while we waited for pirtek to arrive to make some hoses as we didn't like teh avo supplied ones.
Fore completeness of the story the ECU had been chaged prior to installing the kit, if using a plug in ECU or 5th injector set-up I dont imagine that adding more than an hour or so to the fitment.
I'd be happy to take on the challenge to fit an AVO kit in a day again if anyone has a car and kit, although I am not liscenced, so not sure where we'd stand on that.
