right forum i hope
How is offset measured. Any one know the offset for a 2000 Laser I do have a valid reason for asking this
Cheers John
Offset???
- Hellmun
- Vehicle: NB8B - Turbo
It's measured in Millimeters. It's the distance from the centre of the rim to where the wheel attaches to the hub. E.g a 0 offset means the plate where the wheel nuts are screwed on is in the dead centre of the wheel. If it was a 200 wide tyre this would be at the 100mm mark from either side of the wheel. Positive offsets place the wheel hub further towards the outside of the car.
- Hellmun
This site will have a picture which should make it easier to understand what I mean. I don't know what a laser's standard wheel offset is though offhand.
http://www.carbibles.com/tyre_bible.html
- StanTheMan
It should be stamped on the Laser's standard rims.
Just remember that as rim widths change so do offsets... a +20mm offset on a 6 inch rim is entirely different to a +20 offset on a 8 inch rim for example
Last edited by Adam_NAclubman on Wed Jun 20, 2007 5:23 pm, edited 2 times in total.
- StanTheMan
Users browsing this forum: No registered users and 169 guests
