Light weight 17s
blackster
Light weight 17s
Postby blackster » Mon Jun 11, 2007 2:54 pm
Im looking for some light weight 17s for the SE, the 17' OEM racing hearts have a x4 stud pattern 40mm offset and currently weigh 18kg with the tyre. I believe the rim weight is about 11kg.
Locally the only rim that I have across that should fit is the Lenso Light S-2.
Introducing the all new Lenso Light S-2. Weighing under 7kg. Perfect for small, turbo charged cars which like to get around the track FAST!
Model: Light S-2
Sizes Available: 17x7
Fitment Available: 4x100
Colour/Finish: White / Gold / Black
Anyone fitted this rim and would like to share there experience with them. Secondly, I'm open to suggestions for another substitute, bare in mind it has to be within a similar price range. I understand that going smaller will reduce unsprung weight, but id like to keep the same profile.
Previous
04' MX5 SE.
02' MX5 Classic ed.
ralphie
Postby ralphie » Mon Jun 11, 2007 4:16 pm
SE rims are 18 pounds / 8.2kg.
I think - correct me if im wrong - If you fit those there wouldn't be much different becuase stock is 17x7 et40. Perhaps 17x7.5 would be better to suit as this is what the 205/40r17s are designed to be mounted onto.
Black would be a nice 'color' for those rims.
Postby manga_blue » Mon Jun 11, 2007 5:05 pm
blackster
Postby blackster » Mon Jun 11, 2007 5:24 pm
ralphie wrote:SE rims are 18 pounds / 8.2kg.
10kg for each tyre they didnt feel that heavy, the rim felt heavier then the tyre when i picked them up at the tyre shop. Damn i wish i had access to a scale when i was at the tyre shop.
Yes, if i go for the lenso's they will be black.....
Calling lou, are they lenso's?
Previous
04' MX5 SE.
02' MX5 Classic ed.
CT
Postby CT » Mon Jun 11, 2007 6:04 pm
I have the same wheels - they are Alts from memory....and they are only 15s....... 8)
PUR157
Postby PUR157 » Mon Jun 11, 2007 6:20 pm
Do they have to be 17s?
If you want outright performance...
16s and 15s can go into the region of 5-6kgs (ok... those might be abit exxy)
Whats ur price range?
Oneness of Man and Machine
green_comet
Car Detailing Guru
Postby green_comet » Mon Jun 11, 2007 6:35 pm
If you can go 15's, these are meant to be great.. They would be a very nice wheel for the track.
15x8 +36 offset..
Lightweight 12.9 lb race wheel. One piece cast construction. Double valve design. Nickel painted, durable clear coated finish. JWL approved. Fits 195/50, 205/50/ 225/45, 225/50, 245/40 tires
http://www.949racing.com/index.asp?PageAction=VIEWPROD&ProdID=10
blackster
Postby blackster » Mon Jun 11, 2007 6:50 pm
@ CT, thanks for the brand, they look bigger then 15s, gee lou's car looks really low, much lower then i remember it.
@ PUR157, As mentioned in the initial post, I prefer 17s despite not being the most optimal size as far as performance goes. I do not want to lower the car any further at this point in time as 15s would make the car look like 4X4 ed.
So i thought i good comprimise would be some light weight 17s that look reasonably exxy and could be used for the odd track day.
I got quoted $1250 AUD for the lenso's.
Previous
04' MX5 SE.
02' MX5 Classic ed.
green_comet
Car Detailing Guru
Postby green_comet » Mon Jun 11, 2007 7:45 pm
:? ...I very much doubt that.
john!
Postby john! » Tue Jun 12, 2007 1:30 am
depends how far your budget will stretch and what colour car you are putting your wheels on, but have you though about ssr competition?
http://www.wheelspecs.com/specs/wheelmodels/377
12.7 lbs a wheel in 17x7.5
recently got quoted 2800 for a set in 17x7.5/17x8.5 from these guys http://www.ajperformance.com.au/
hope this helps
john
Benny
Postby Benny » Tue Jun 12, 2007 3:12 pm
If you're looking for the lightest and most affordable wheel in 17\" why not try the Starcorp wheel?
7kg and $220 each from Mania, and if you send me a PM, I might be able to get an even better price for you.
PUR157
Re: Light weight 17s
Postby PUR157 » Tue Jun 12, 2007 3:12 pm
blackster wrote:but id like to keep the same profile.
Oops, sorry. I guess I missed that bit!
How about a set of Buddy Clubs? They should be the go in terms of pure functionality... they mightn't be forged... but they are quality items!
(or so I've heard)
pulled from http://www.buddyclub.com.au
Buddy Club P1 Racing SF
17x7.0 --- +42 --- 7.7 Kg --- $378.00ea.
PS we have an Buddy Club Aust. employee on the Forumite Payroll! Justin Fox I think it was?
mcmonte
Postby mcmonte » Fri Jun 15, 2007 2:17 am
I like the forged Motegi wheels. The only Aussie dealer I can find is Spinners Penrith.
Trak Lite
17x7 is 14.3 lbs (6.5kg)
Trak Lite 2
17x8 is 14 lbs
http://www.motegiracing.com/
The offsets listed are pretty high (+42 - +45)
CT
Postby CT » Fri Jun 15, 2007 9:45 am
+42 works well on an SE. 8)
Garry
Postby Garry » Fri Jun 15, 2007 9:52 am
What is the offset on a SE?
Users browsing this forum: Google [Bot] and 217 guests
