hi guys,
I know there has been lots of discussion regarding camber adjustments for track use. One thing which i can't seem to find are tow settings. Im getting a wheel alignment/cambre adjustment on Tuesday (going to wakefiled on Thursday) Ive opted to set the camber at -2 all round. What tow setting should i use/do people recommend. Sorry but im a bit of a noob when it comes to this sort of thing. If this has been discussed before please forward me the link. Thanks in advance.
Jimmy
Camber and Tow settings for track.
- Jimmy
- bigdog
- King of the kennel
- CT
- Jimmy
im running on a couple of dunlop somethings (really crap ones) on the rear and no name things on the front. i aim to shred them so i can get some proper tyres on the car. i dont have much grip at the moment! (they came with the car!) coz im running road tyres which i couldnt care less about, im not overly concerned if they are running a little thin by the end of the day. i just want them off asap.
thursday ive got a bunch of uni mates heading to wakefield. we've got about 10 or so cars going atm (a couple of 5's, XY, Swift GTi, ...) Should be a good day!
- Jimmy
on another note, has anyone from the Canberra region dealt with ACDC in Mitchell. Im getting my wheel alignment done there. I spoke with the bloke there today and he seems really really precious with his work (a good thing) He claims that his alignment machine is the only one in Aus, importing it from germany when he moved here. It measures down to fractions of a minute, rather than fractions of a degree, all completely computer automated with every car you can think of programmed into it with original factory specs! was very impressed
- Russellb
- RIP Nov 2014
If your car is at STD height you'll lucky to get -1deg on the front
and -1.5 on the rear
I run 3mm toe in on the rear and 2mm toe in on the front
I like the feal of these setting on my car
ACDC Are great mob they do my car
My ClubmanRebuild
MX5 SE Rally car is HERE
JimmyJ5 wrote:on another note, has anyone from the Canberra region dealt with ACDC in Mitchell. Im getting my wheel alignment done there. I spoke with the bloke there today and he seems really really precious with his work (a good thing) He claims that his alignment machine is the only one in Aus, importing it from germany when he moved here. It measures down to fractions of a minute, rather than fractions of a degree, all completely computer automated with every car you can think of programmed into it with original factory specs! was very impressed
We tend to use Jon at Tyrepower at Tuggers. He has our preferred specs programmed in his machine and offers a club discount. Very particular about his work too. When you see the factory specs you wouldn't want to go near them Forget minutes - the factory specs are +/- 1.5 degrees from memory.
Russ is right - on a std height car you won't get a great wheel alignment and will have to compromise your castor to get enough camber.
- Russellb
- RIP Nov 2014
FYI Casey I had the race car on the Alinger today.
max camber I could get was 7.5Deg Neg
set it up to 4.5 neg front and 3.5 rear
should be some fun next weekend at the track
My ClubmanRebuild
Russellb wrote:FYI Casey I had the race car on the Alinger today.
Is that with those funny reject bushes that the manufacturer couldn't get the holes centred properly
7.5 degrees would stretch the braking out a bit
- Russellb
- RIP Nov 2014
modifiyed lower arms and Offset Bushes
doing it to pilsners car over the weekend .
What you up to this weekend ? can you get a leave pass for a spin in the race car ?
I have some dealer plates for the weekend for tuning
At the shop all day sunday
My ClubmanRebuild
Users browsing this forum: No registered users and 195 guests
